  Softwarefehler in Pro/E
Autor Thema:  Softwarefehler in Pro/E (1308 mal gelesen)
Giggel
Sehen Sie sich das Profil von Giggel an!   Senden Sie eine Private Message an Giggel  Schreiben Sie einen Gästebucheintrag für Giggel
erstellt am: 18. Dez. 2003 07:19    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hallo Pro/E-Anwender,
anbei ein "Weihnachtsgeschenk" von PTC
Dear PTC Customer:
The purpose of this communication is to inform you of an important software issue that has recently been identified and corrected that will affect numerous Pro/ENGINEER, Pro/INTRALINK, and Windchill customers worldwide. Specifically, this software issue may cause certain inter-process communications between Pro/ENGINEER and related application modules to "time-out" prematurely on January 10, 2004 and thereafter. This issue, which affects Pro/ENGINEER and related products, does not corrupt data but may impact productive utilization of the software unless addressed before January 10, 2004.
This isolated software issue can be readily addressed via a small downloadable software patch or by implementing a new maintenance build of the release of the software you have currently deployed. Nonetheless, PTC believes it to be prudent to notify customers to give you ample time to address this issue prior to January 10, 2004 and avoid any interruptions to your use of the software. We encourage all Pro/ENGINEER, Pro/INTRALINK, and Windchill customers to visit http://www.ptc.com/go/timeout to determine how this issue may affect your implementation. This Web site will provide you with a description of the problem, a timeline showing when various solutions to this issue will be made available, and what actions will be required to implement those solutions.
Over the past several releases, PTC has demonstrated our commitment to continuous improvement of the quality of our software. I want to assure you that quality remains our top priority and we are investing heavily in quality assurance.
Should you have any questions once you have read the material posted on the Web site, please do not hesitate to contact PTC's Customer Support organization. Our staff is prepared to support you through this update. We value your business, and I apologize in advance for any inconvenience that we may have introduced.
Regards,
Jim Heppelmann
EVP & Chief Product Officer
Giggel
snoopyD
Sehen Sie sich das Profil von snoopyD an!   Senden Sie eine Private Message an snoopyD  Schreiben Sie einen Gästebucheintrag für snoopyD
erstellt am: 18. Dez. 2003 07:43    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Giggel 10 Unities + Antwort hilfreich
...ähmm, könnte das mal bitte jemand übersetzen. Soweit ich das verstehe laufen alle Pro/E Lizenzen am 10.01.2004 aus. Und auf der Homepage von PTC http://www.ptc.com/go/timeout  kann man sich nen Patch runterladen.
Hat das schon jemand probiert?
snoopyD
;-} snoopyD
Giggel
erstellt am: 18. Dez. 2003 07:53    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hallo snoopyD,
das hast Du soweit schon richtig verstanden,
aber den Patch gibts erst ab Freitag (siehe: http://www.ptc.com/go/timeout/faq.htm).
Giggel
anagl
CREO2 M140
PDMLink 10.2 M020
HW diverse
erstellt am: 18. Dez. 2003 08:06    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Giggel 10 Unities + Antwort hilfreich
Original erstellt von snoopyD:
Soweit ich das verstehe laufen alle Pro/E Lizenzen am 10.01.2004 aus. Und auf der Homepage von PTC http://www.ptc.com/go/timeout/  kann man sich nen Patch runterladen.
Nein und nochmals nein
das Problem hat mit der nmsd.exe zu tun, die die Kommunikation zwichen Pro/E und INTRALINK und anderen Applikation z.B. J-Link steuert
siehe auch http://ww3.cad.de/foren/ubb/Forum69/HTML/000296.shtml
vielleicht auch http://ww3.cad.de/foren/ubb/Forum69/HTML/000235.shtml
Naja hoffen wir mal
Alois
[Diese Nachricht wurde von anagl am 18. Dez. 2003 editiert.]
