 | NVIDIA RTX PRO 6000 Blackwell Max-Q Workstation Edition, eine Pressemitteilung
Thema: Pneumatic Cilinder Simulation (1889 mal gelesen)
Symen Mitglied Student
 Beiträge: 9 Registriert: 08.12.2007
erstellt am: 08. Dez. 2007 11:07 <-- editieren / zitieren --> Unities abgeben:
Hello, I'm trying to simulate a pneumatic cilinder in Dynamic Simulation, it has to go in and out (repeatingly) to make the press work (see picture). The system works now, but with an invisible crank+rod. (the cilinder has a realworld force of 740N, but it isn't neccery to simulate the force, it has to complete the 100mm strokes.) Thanks in advance and regards from the Netherlands, Symen Kalsbeek Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
 Beiträge: 11582 Registriert: 30.04.2004 WIN10 64bit, 32GB RAM IV bis 2022
erstellt am: 08. Dez. 2007 11:44 <-- editieren / zitieren --> Unities abgeben:          Nur für Symen
Wellcome, do you know it is a german speaking forum. Witch version of IV you are using? What kind of graficcard you are using and witch driverversion? I was looking in the forum-search but with sumilation an unvisible, i got no hits. best regards Sascha Fleischer [Diese Nachricht wurde von freierfall am 08. Dez. 2007 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 08. Dez. 2007 11:57 <-- editieren / zitieren --> Unities abgeben:
Yes, I know it's a german speaking forum, but i think it's one of the best inventor forums. I have a hard time typing german. But I can read it without much trouble. I hope it's ok I'm Using inventor 2008 pro. I have no problems with the software/drivers. I'm running the simulation with an extra crankshaft+rod (I turned visibility of those off). But i want to run it with a pneumatic Cilinder. but had no luck trying to get it working. this is how i simulate it now. but the handle should be pushed and pulled by a cilinder. [Diese Nachricht wurde von Symen am 08. Dez. 2007 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
pepper4two Mitglied
 Beiträge: 1133 Registriert: 30.11.2003 Dell Precision M6800; Intel® Core™ i7-4810MQ Prozessor; 32GB (4x8GB) HyperX HX316LS9IB/8 1600MHz DDR3L; AMD FirePro M6100 2GB GDDR5; UltraSharp FHD (1.920 × 1.080); Hybrid-SATA-Festplatte, 2,5 Zoll, 5oo GB, 6 Gbit/s, 8 GB Flash-Speicher; Spaca Mouse Pro Wireless; Cad Mouse; SWX 2013 SP5
erstellt am: 08. Dez. 2007 12:10 <-- editieren / zitieren --> Unities abgeben:          Nur für Symen
Hello Symen, in the described case i would suggest to transfer your assembly into a simple presentation (You wrote that you dont need the forces)and animate it there. Best regards Matthias ------------------ Nihil Ex Nihilo [Diese Nachricht wurde von pepper4two am 08. Dez. 2007 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 08. Dez. 2007 12:21 <-- editieren / zitieren --> Unities abgeben:
Thank you Matthias for your reply, I would rather do it in dynamic simulation, the 3D contact body's are working very nice for the "ratchet" system. Can you give a cilinder a fixed speed and travel? that would be all that's needed to make the cilinder push and pull. [Diese Nachricht wurde von Symen am 08. Dez. 2007 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
 Beiträge: 13007 Registriert: 29.08.2003 Toshiba Encore mit MS Office Ein Programm sollte nicht nur Hand und Fuß, sondern auch Herz und Hirn haben. (Michael Anton)
erstellt am: 08. Dez. 2007 13:16 <-- editieren / zitieren --> Unities abgeben:          Nur für Symen
Zitat: Original erstellt von Symen: ... Can you give a cilinder a fixed speed and travel? ...
Welcome to CAD.DE and AUGCE! Four important links for a trouble-free start: Asking Right - Nettiquette - Search Function - System-Info All informations in German though. Of course you can give a cylinder a fixed speed and travel. You can simulate any function for the motion of the cylinder. Use a "Prismatic Joint" between the cylinder tube and the piston rod. Then right click on this joint and use "Properties" to edit the translative degree of freedom "dof1(T)". With "Edit imposed motion" you can define what movement the piston rod should make at which time. You can use the "Position" option and the input grapher to define the motion in relation to time. You can use any mathematical function and condition for the motion. Maybe a sine wave is a good start for a repeated motion. ------------------ Michael Puschner Autodesk Inventor Certified Expert Scholle und Partner GmbH
erstellt am: 08. Dez. 2007 14:18 <-- editieren / zitieren --> Unities abgeben:          Nur für Symen
erstellt am: 08. Dez. 2007 16:37 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 08. Dez. 2007 18:28 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 08. Dez. 2007 23:10 <-- editieren / zitieren --> Unities abgeben:          Nur für Symen
