 | Light + Building 2026: Rittal und Eplan bringen Tempo in Energie- und Gebäudeinfrastruktur, eine Pressemitteilung
Thema: Export ELCAD 7.3 Project to ePlan 1.8.5 (6523 mal gelesen)
padfoot Mitglied
 Beiträge: 26 Registriert: 02.06.2013
erstellt am: 02. Jun. 2013 14:05 <-- editieren / zitieren --> Unities abgeben:
Hello I'm sorry for typing in English here. I've searched the web to find a solution for my problem but had no luck. The only forum that was close to my problem is here! So, I'll be grateful if you help me. I have no problem with answers in German. So just answer my question please. I want to export an ELCAD 7.3 project and import it to ePlan 1.8.5. I've read ELCAD help and follow these instructions: - Go to the menu: Extras -> Services -> EPL Write - Target Drive/Path: d:/eplan4/p/elc2epl - Target Project: master - Path of CFG Data: C:/Program Files/Elcad 7.3/USR/AUCO.73 - Name of CFG File: elc2epl - CFG File: CFG - OK - Then Batch Proccess will begin. ELCAD help says: Zitat:
Data created: The EPL write processor automatically generates the following directory structure in the specified drive: --EPLAN4 +--N ¦ +--ELC2EPL ¦ +--MUSTER +--P +--ELC2EPL +--MUSTER.P The directory d:\eplan4\n\elc2epl\master contains the "normal master files" of the converted project. This includes among other things the symbol files and the plot frames. There the symbol files: AELCAD.SYM Moreover the directory contains all of the plot frames used in the project: xxxxyyyy.SKG The directory d:\eplan4\p\elc2epl\muster.p contains the EPLAN project data.
But in this case, the folder "d:\eplan4\n\elc2epl\master" is empty and just some small files created in this path: D:\eplan4\p\elc2epl\master.P I could not find symbols file or frame file or project file or anything! Should I rename the file extension? Also, I attached the log file of ELCAD conversion. Does anyone convert a project like this? What should I do? Thank you for your help.
[Diese Nachricht wurde von padfoot am 02. Jun. 2013 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
padfoot Mitglied
erstellt am: 02. Jun. 2013 14:14 <-- editieren / zitieren --> Unities abgeben:
 Beiträge: 15740 Registriert: 09.03.2001 EPLAN Electric P8 Professional 2.7.x Expertenmenü :) ---
erstellt am: 02. Jun. 2013 15:22 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
django Moderator Elektrokonstrukteur
 Beiträge: 2982 Registriert: 12.02.2002 EPLAN 3.33 EPLAN 5.xx P8 1.9.6 P8 1.9.10 P8 1.9.11 P8 2.0.9 - 2.8 alle Prof.
erstellt am: 02. Jun. 2013 17:07 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
You can only export from ELCAD to EPLAN 5.7 direkt. You can convert after that the project to P8. This is the only way that function. But you will have a problem with converting the project from 5.7 to P8. The problem will be the symbol libary. I don´t think that will work. I can try it for you if you send me the 5.7 project. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 02. Jun. 2013 17:11 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
I´ve check the log file. The main Problem is that you use own macros ans symbols. Those symbols are not able to export so easy. To export a ELCAD project to Eplan you have to make your plan by several specifications. If you don´t do this it won´t be able to export it to eplan. This is my knowledge. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
padfoot Mitglied
erstellt am: 02. Jun. 2013 21:51 <-- editieren / zitieren --> Unities abgeben:
1. Thank both of you for your answers. 2. I've never worked with ePlan 5.7. Just P8! After converting ELCAD to ePlan 5.7, can I use P8 to convert it again?! 3. You said I have to make the project by several specifications. What did you mean? Please guide me! I'm really a newbie! 4. What should I send to you? ELCAD project, or converted files? (I think converted files are not correct, because file sizes are tiny! There is just ten files in a folder [master.P I think].) 5. Thanks to "Google Translate", I can read your posts in German or any other languages!  6. Thank you again.
erstellt am: 03. Jun. 2013 06:47 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
I only know that there is a document from ELCAD (i never worked with ELCAD) where it shows how to make a project that will be converted to EPLAN 5.7. You can send me the converted EPLAN 5.7 project. I will try for you to bring it to P8. Hope that helps. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
padfoot Mitglied
erstellt am: 03. Jun. 2013 08:03 <-- editieren / zitieren --> Unities abgeben:
padfoot Mitglied
erstellt am: 03. Jun. 2013 10:21 <-- editieren / zitieren --> Unities abgeben:
I had some problems with ELCAD symbols. I tried to fix them then convert the project again. Some additional files will create now, but at the end of conversion, they will be deleted! I tried to close the conversion dialog before deleting files, then I can save these files. I think the main ePlan5 converted files are here. (But maybe uncompleted) I've attached these files to this post. Can you please check them and tell me if they are OK? Thanks a lot. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
robroy55 Ehrenmitglied V.I.P. h.c. Selbständiger Konstrukteur Elektrotechnik
 Beiträge: 2614 Registriert: 13.07.2005 Elcad V5/V7 Prof. EngineeringBase V6 Prof./Power/EVU Eplan V5/P8 Prof. Sigraph(SPEL-D) V5/V8/V9/V10 Wscad V4/V5/Suite Prof. Ruplan V4.7/V4.8 Std/EVU Autocad LT 2007
erstellt am: 03. Jun. 2013 11:54 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
Hi patfood, if django can't help you there is another way to convert this project. You can contact OpenCAE if you want. I have convert a lot with this company and it works very good. But you have to pay for it! ------------------ Grüße aus Frangn Rob Habe keine Angst etwas Neues im Leben auszuprobieren. Denke einfach daran, dass Amateure die Arche erbaut haben und Profis die Titanic. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
padfoot Mitglied
erstellt am: 03. Jun. 2013 12:25 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 03. Jun. 2013 12:51 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
erstellt am: 03. Jun. 2013 12:52 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
VoCAE Mitglied Elektrotechnikermeister
 Beiträge: 67 Registriert: 10.06.2010 EPLAN P8 2.2 HF1 ELCAD 7.8.0
erstellt am: 03. Jun. 2013 12:55 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
Hello padfoot, i think, your problem is, that elc2epl-processor is missing the symbols in the symbollibary. When you open the Project in elcad, the pages are showing correctly? in you masterproject eplan 5 shows all graphics and connection BTW . symbols. the symbols are away. Set the right libary in the project options an d try it again. best regards Andi Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
padfoot Mitglied
erstellt am: 03. Jun. 2013 13:54 <-- editieren / zitieren --> Unities abgeben:
| | Elektrokonstrukteur EPLAN P8 (m/w/d) | Herausforderungen liebst du? Dann bist du bei uns genau richtig! Du bist motiviert, sorgst für einen regelmäßigen Austausch mit unseren Kunden und gibst immer Vollgas. Du liebst Herausforderungen und möchtest nun richtig durchstarten. Du arbeitest gerne im Team und bist bereit, vollen Einsatz bei unseren Veranstaltungen und am Telefon zu geben. Für dich ist es wichtig, langfristige Kundenbeziehungen aufzubauen.... | | Anzeige ansehen | Feste Anstellung |
erstellt am: 03. Jun. 2013 14:24 <-- editieren / zitieren --> Unities abgeben:          Nur für padfoot
Zitat: Original erstellt von padfoot: Thank you for your offer. But I don't have time to wait until they can redraw my project. If I wont succeed with converting, I must learn ELCAD and work with it!
OpenCAE wouldn't redrawing your project, they convert it! This company has an own converter for several CAE-Systems. ------------------ Grüße aus Frangn Rob Habe keine Angst etwas Neues im Leben auszuprobieren. Denke einfach daran, dass Amateure die Arche erbaut haben und Profis die Titanic. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
