  Timeout ab 10.01.2004
Autor Thema:  Timeout ab 10.01.2004 (3902 mal gelesen)
michaeln
Sehen Sie sich das Profil von michaeln an!   Senden Sie eine Private Message an michaeln  Schreiben Sie einen Gästebucheintrag für michaeln
WF2 M250, ProI 3.4 M030
Inventor 11 SP4
WinXP-x64 SP2, Ubuntu 8.10
erstellt am: 18. Dez. 2003 07:17    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Zur Info für alle, die keine Post direkt von PTC bekommen:
Dear PTC Customer:
The purpose of this communication is to inform you of an important software issue that has recently been identified and corrected that will affect numerous Pro/ENGINEER, Pro/INTRALINK, and Windchill customers worldwide. Specifically, this software issue may cause certain inter-process communications between Pro/ENGINEER and related application modules to "time-out" prematurely on January 10, 2004 and thereafter. This issue, which affects Pro/ENGINEER and related products, does not corrupt data but may impact productive utilization of the software unless addressed before January 10, 2004.
This isolated software issue can be readily addressed via a small downloadable software patch or by implementing a new maintenance build of the release of the software you have currently deployed. Nonetheless, PTC believes it to be prudent to notify customers to give you ample time to address this issue prior to January 10, 2004 and avoid any interruptions to your use of the software. We encourage all Pro/ENGINEER, Pro/INTRALINK, and Windchill customers to visit http://www.ptc.com/go/timeout to determine how this issue may affect your implementation. This Web site will provide you with a description of the problem, a timeline showing when various solutions to this issue will be made available, and what actions will be required to implement those solutions.
Over the past several releases, PTC has demonstrated our commitment to continuous improvement of the quality of our software. I want to assure you that quality remains our top priority and we are investing heavily in quality assurance.
Should you have any questions once you have read the material posted on the Web site, please do not hesitate to contact PTC's Customer Support organization. Our staff is prepared to support you through this update. We value your business, and I apologize in advance for any inconvenience that we may have introduced.
Michael
hagen123
Application Specialist
Pro/Engineer Wildfire 4
Pro/Intralink 3.4
erstellt am: 18. Dez. 2003 08:26    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
faq.pdf
... hab ich auch heute bekommen, scheint kritisch zu sein...
... soll eigentlich heissen, dass ab 10.01.2004 nichts mehr gehen kann, ausser man holt sich den software-patch
... finde ja mal wieder gut, das ein paar tage vor weihnachten die mail rumgeht...
... auf jeden fall mal auf den o. g. link gehen und die vier-seitig pdf-f a q runterladen, da steht alles sehr gut drin (natuerlich in englisch)
... so long
... ach was, ich haeng das einfach mal mit ran
-che-
CATIA V5 Ausbilder
Sehen Sie sich das Profil von -che- an!   Senden Sie eine Private Message an -che-  Schreiben Sie einen Gästebucheintrag für -che-
erstellt am: 18. Dez. 2003 11:46    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
hi,
.. na das ist ja mal wieder ein dicker-hund.
wie können die den in ihren programmcode ein festgelegtes datum für prozessabfragen setzen, und den noch über mehrere versionen mitschleppen .....
.. ziemlich peinlich!..
bernhard.veckes
Creo / PDMLink - Admin
Sehen Sie sich das Profil von bernhard.veckes an!   Senden Sie eine Private Message an bernhard.veckes  Schreiben Sie einen Gästebucheintrag für bernhard.veckes
Creo Parametric 4.0 M150
Creo Parametric 8.0.3.0
PDMLink 12.0.2.2
erstellt am: 18. Dez. 2003 12:32    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
siehe Pro/Intralink-Forum,
wenn's gut geht, dann ist nur die nmsd.exe auszutauschen. Näheres wird wohl hoffentlich morgen auf der Downloadseite www.ptc.com/go/timeout zu sehen sein.
  Bernhard Veckes
manuki
Fahrzeugtechnikinscheniör
Creo 1.0
CATIA V5 R20
CoCreate Modeling 18.0
erstellt am: 18. Dez. 2003 16:50    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
aktueller Stand 18.12.16:30 lt. PTC Customer Support:
- es wird reichen, die nmsd.exe zu ersetzen
- zusätzlich gibt es (optional) ein neues ptcsetup, um die installation zu aktualisieren
Schon ein peinlicher Vorfall, aber wenn's dabei bleibt, dass man eine Datei ersetzen muss, naja, ok.. Nicht auszudenken, wenn das am 11.01.04 durch 2,5 Millionen gleichzeitige Anrufe bei der Hotline rausgekommen wäre, weil bei sämtlichen PTC Kunden die Arbeit ruht...
Guten Rutsch und viel Spass beim Updaten,
Manuel
candrian
Sehen Sie sich das Profil von candrian an!   Senden Sie eine Private Message an candrian  Schreiben Sie einen Gästebucheintrag für candrian
DELL M60<P>Pro/E 2001, WILDFIRE 1, WILDFIRE 2
CATIA V5 R12
erstellt am: 18. Dez. 2003 18:55    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Da kann schon mal dem besten Programmierer passieren!
Einige Infos:
Der Bug stammt aus der Urzeit von UNIX, genauer gesagt entstand er bereits mit dem Urknall am 1.1.1970. Und nun ca. 1,07 Gigasekunden später, was ca. 34 Jahren entspricht, laufen einige Felder ins Leere....
Wer nachrechnet kommt auf genau 2^30 Sekunden.
Der Fehler ist erst gestern aufgetaucht und PTC hat prompt reagiert - die Community ist nun gefragt mitzuhelfen, dieses Patch zu verteilen. (wenns dann da ist...)
candrian
michaeln
Inventor 11 SP4
erstellt am: 18. Dez. 2003 20:26    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Original erstellt von candrian:
candrian
Ist der Fehler nicht schon längere Zeit bei PTC bekannt?
Denn so wäre das ca. 2-3 Wochen verzögerte Erscheinen von ProE2001 2003440 und Wildfire 2003450 (war ja für ein paar Stunden auf dem Server zum Download) zu erklären. Über den Update Advisor sind keine grundlegenden Probleme zu sehen, die das Zurückhalten der neuen Wochenversionen erklären würde.
Michael
hagen123
Pro/Intralink 3.4
erstellt am: 18. Dez. 2003 21:39    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
laut f a q soll ptc dies seit dem 12.12.03 wissen (jedenfalls offiziell) - (ist ja immer gut in der weihnachtszeit bekannt zu geben)
... so long
michaeln
Inventor 11 SP4
erstellt am: 19. Dez. 2003 07:31    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Die Lösung naht.
Zumindest für ProE2001 gibt es schon eine nmsd.exe zum Download.
Siehe: http://www.ptc.com/go/timeout/technical_resource.htm
Michael
-che-
CATIA V5 Ausbilder
erstellt am: 19. Dez. 2003 13:53    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
sagtmal, ...
müssen alle nmsd's ausgetauscht werden, auch die in promech und proiclient ? ...
bernhard.veckes
PDMLink 12.0.2.2
erstellt am: 19. Dez. 2003 14:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo Zusammen,
laut Hotline wird die nmsd.exe der Anwendung angezogen, die als erstes gestartet wird. Wird also Pro/I gestartet, so wird auch die aus dem ILink-Client angezogen.
Ich habe die nmsd.exe (den Patch) sowohl im Pro/E 2001 Client als auch im Pro/I 3.2 Client ausgetauscht. Dann die Systemzeit auf Dez 2004 gesetzt und es lebt.
Siehe auch:
http://ww3.cad.de/foren/ubb/Forum69/HTML/000296.shtml
Mit freundlichen Grüßen
Bernhard Veckes
AndreasD
Sehen Sie sich das Profil von AndreasD an!   Senden Sie eine Private Message an AndreasD  Schreiben Sie einen Gästebucheintrag für AndreasD
Betriebssystem:
Linux SUSE10
Windows2000
CAD System:
Wildfire 2 M230
erstellt am: 30. Dez. 2003 19:44    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo zusammen....
Kann mir jemand eine KLARE antwort geben!!
Frage:
ich benutze weder Pro/INTRALINK noch Pro/TOOLKIT ! ich konstruiere einfach nur mit Pro/E.
was passiert mir jetzt an diesem 10.01.2004 ?
Geht mein proE noch oder geht es nicht mehr ?!
mfg andreas
ZITAT: http://ww3.cad.de/foren/ubb/Forum12/HTML/004710.shtml
"...die Patchinstallation kommt es bei der Kommunikation von Pro/ENGINEER mit anderen Applikationen (Pro/INTRALINK, Pro/TOOLKIT Applikationen ...) zu Zeitüberschreitungen (time-out).
Dadurch ist Ihre bisherige Arbeitsweise nicht mehr möglich..."
bernhard.veckes
erstellt am: 30. Dez. 2003 21:50    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo Andreas,
das Problem betrifft die Kommunikation von Pro/E mit anderen Produkten. Wenn es keine Kommunikation gibt, dann gibt es auch kein TimeOut-Problem.
Bernhard Veckes
Dammerl
Project Manager
Sehen Sie sich das Profil von Dammerl an!   Senden Sie eine Private Message an Dammerl  Schreiben Sie einen Gästebucheintrag für Dammerl
erstellt am: 05. Jan. 2004 09:42    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo Andreas,
ich würde allerdings trotzdem das Patch installieren - ist ja auch kein großer Aufwand. Auch wenn es jetzt nicht nötig erscheint, wenn Du z.B. in 2 Jahren eine andere Applikation dazunimmst, wirst Du Dich möglicherweise nicht mehr an dieses Problem erinnern und verzweifel, dass Du Pro/E nicht zum Laufen bringst. Wenn man eine neue Wochenversion installieren will, muss man die alten vorher deinstallieren. Zumindest verstehe ich den das so (siehe http://www.ptc.com/go/timeout/technical_resource.htm ). Ich weiß nicht, ob das immer so bleiben wird, oder ob man das sich sparen kann, wenn man einmal das Patch installiert hat. Vielleicht weiß jemand anderes mehr dazu ...
Grüße und Frohes Neues!
Tom
AndreasD
Betriebssystem:
Linux SUSE10
Windows2000
CAD System:
Wildfire 2 M230
erstellt am: 05. Jan. 2004 10:23    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Original erstellt von manuki:
Manuel
also ich werde dann wohl die nmsd.exe runterladen und einfach mit der alte austauschen. sollte doch funktionieren !? hoffendlich !
mfg Andreas
Dammerl
Project Manager
erstellt am: 06. Jan. 2004 09:20    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Leute,
ich habe noch eine Frage zum Software-update. Auf den PTC-Seiten heißt es, dass man Pro/E erst deinstallieren muss, bevor man einen neuen Datencode (z.B. 2003451) installiert. Gilt das nur solange, solange die alte nmsd existiert, oder muss man das jetzt einmal machen, egal ob man jetzt updated, oder erst in einigen Wochen / Monaten? Weiß da jemand etwas dazu?
Tom
michaeln
Inventor 11 SP4
erstellt am: 06. Jan. 2004 11:45    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hallo Tom,
so wie es aussieht, muß man das einmal machen, sobald man Wildfire 2003451 oder eine neuere Wochenversion installiert.
ProE2001 scheint davon übrigens nicht betroffen zu sein. Da wird nur von einer Update-Installation gesprochen.
Michael
giatsc
 CAD/PDM Consultant
Sehen Sie sich das Profil von giatsc an!   Senden Sie eine Private Message an giatsc  Schreiben Sie einen Gästebucheintrag für giatsc
erstellt am: 06. Jan. 2004 15:53    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo alle und ein gutes 2004 (das ja PTC mässig ein wenig wackelig anfängt)
Unsere internen Test's mit dem Bug haben ergeben, dass vor allem Toolkit-Applikationen stark betroffen sind.
(Keine Initialisierung mehr)
Also alle Anwender von 3.Produkten wie PRO.FILE, Coordtable, Gearwheel usw.:
unbedingt Patchen!
Trotzdem frohes schaffen mit der (trotzdem) besten CAD Software worldwide...
Gruss Thomas
Mit CAD zu arbeiten ist besser als gar keine Arbeit!
ProPit
Sehen Sie sich das Profil von ProPit an!   Senden Sie eine Private Message an ProPit  Schreiben Sie einen Gästebucheintrag für ProPit
WF3 auf WIN XP
erstellt am: 07. Jan. 2004 15:32    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Hallo Forum,
tschuldigung - ich blick noch nicht durch:
ich arbeite als Einzelkaempfer mit Wildfire + BuW an einem einzelnen Win-XP Rechner.
Folglich soll ich wohl auf 2003451 updaten.
a) benoetige ich die neuen Dateien zum Setup und NMSD trotzdem ?
b) ... und was ist FTP, HTTP, Primary-, Secondary-, und Backup-Server
c) wie kann ich meine bestehende Pro/E Installation deinstallieren und dabei alle Einstellungen, Vorlagen usw. fuer die Neuinstalltion behalten ?
Bin fuer alle Hinweise dankbar.
Gruss Peter
andschne
Sehen Sie sich das Profil von andschne an!   Senden Sie eine Private Message an andschne  Schreiben Sie einen Gästebucheintrag für andschne
erstellt am: 07. Jan. 2004 15:46    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
wildfire-i486_nt_nmsd.zip
Hallo Peter,
Einer ist immer der looser
einer wird immer verlieren
heute bist du mal der looser ........
Spass bei seite!
Hohl dir den richtigen Patch sonst geht ab samstag mittag nichts mehr!
Updaten brauchst du nicht sondern nur die Richtige nmsd.exe
das sind 72kb im vergleich zu 2,1GB
(Datei sollte gleich als anhang an diesem bericht hängen)
Andreas
Stahl
unbeschreiblich
Sehen Sie sich das Profil von Stahl an!   Senden Sie eine Private Message an Stahl  Schreiben Sie einen Gästebucheintrag für Stahl
Proe 18 bis Creo 3
Intralink 1 bis 3.4
Windchill PDMLink 8.0 bis 10.2
erstellt am: 07. Jan. 2004 15:49    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
a) Du benötigst die neue nmsd.exe wegen B&W. Aber auch ohne B&W würd ich trotzdem das nmsd.exe ersetzen, das File ist sehr klein und schnell downgeloadet.
Der Patch von ptcsetup ist NUR für Unix notwendig!
b) Weil sicher viele PTC Kunden gleichzeitig downloaden wollen, haben die das auf 3 Server verteilt. Kannst Dir einen der drei aussuchen. Und ob FTP oder HTTP ist geschmackssache. Ich hab HTTP und den Backup Server genommen.
c) Das ist nur umfangreich zu beantworten. Normalerweise sollten Anpassungen und Software strikt getrennt sein. Die einzige "Verknüpfung" zwischen den beiden Bereichen bildet die config.pro im proe_dir\text Verzeichnis. Wenn Du die (und die config.win) sicherst, dann kann eigentlich nichts schiefgehen, ausser Du hast noch zusätzlich Anpassungen ins ProE verzeichnis hineigestellt...
Benutzt Du allerdings eine fertige Konfigurationsumgebung wie zB die StartupTools, brauchst Du Dir keine Sorgen machen, dann kann ProE gefahrlos gelöscht werden.
Ich würde vorschlagen den ProE Installationsordner umzubenennen, dann ProE neu installieren (und zwar ins selbe Verzeichnis wies vorher war) und dann zu schauen ob noch alles geht... Wenn ja kann man den umbenannten alten Ordner ja irgendwann löschen.
Stahl.
ProPit
erstellt am: 07. Jan. 2004 16:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
@ Andreas und Stahl,
vielen Dank fuer die schnellen Antworten.
@ Andreas
Ich hoffe, dass ich ueber dieses Thema auch bald entspannt lachen kann. (Bisher noch etwas verkrampft.)
Gruss Peter
cadmech
Systemmanager CAD
Sehen Sie sich das Profil von cadmech an!   Senden Sie eine Private Message an cadmech  Schreiben Sie einen Gästebucheintrag für cadmech
Dell Precision
380 / 390 / T3400
FX1400 / FX1500 / FX1700
4 GB RAM
erstellt am: 07. Jan. 2004 17:17    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Was funktioniert eigentlich nicht mehr nach dem nächsten Samstag?
giatsc
 CAD/PDM Consultant
erstellt am: 07. Jan. 2004 17:21    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für michaeln 10 Unities + Antwort hilfreich
Einfach schön diesen Beitrag durchlesen.
Mehr weiss schlussendlich keiner.
Ab 11.1.04 sind wir alle schlauer....
...sofern wir Sonntags arbeiten
Gruss Thomas
Mit CAD zu arbeiten ist besser als gar kein Job!
[Diese Nachricht wurde von giatsc am 07. Jan. 2004 editiert.]
