  Rund um AutoCAD
  Inhalte neuer Acad Version?
Exklusives EDU-Programm für RTX PRO Blackwell, eine Pressemitteilung
Autor Thema:  Inhalte neuer Acad Version? (329 mal gelesen)
CADwiesel
CAD4FM UG
Sehen Sie sich das Profil von CADwiesel an!   Senden Sie eine Private Message an CADwiesel  Schreiben Sie einen Gästebucheintrag für CADwiesel
AutoCAD, Bricscad
Wir machen das Mögliche unmöglich
erstellt am: 05. Dez. 2004 12:30    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
What's New in Upcoming Autodesk Software
During the keynote address of Autodesk Univeristy 2004 this week, Autodesk revealed publically to 4,400 attendees some of the features that might appear in future releases of AutoCAD and Inventor.
For AutoCAD:
* Dynamic blocks - these are much like the symbols found in the now-abandoned Actrix product. These blocks have shape-coded handles that indicate whether the block can be rotated in increments, stretched, aligned, and so on. Just like the oft-used demo back in the Actrix days, Autodesk showed how stretching a conference table stretches it in pre-defined increments, as well as adding more chairs.
* Dynamic input - this moves the "command line" to the object being edited. Autodesk shows how the command's prompts and coordinate input are displayed in small yellow boxes next to the object. For example, in drawing a line, the angle and length are displayed, each of which can be adjusted dynamically, locked, or overridden at the keyboard.
For Inventor:
* 3D grips - these are like those found in Tri-spectives and IronCAD. You interactively change the size and location of parts in assemblies.
* Drag'n drop parts - these parts are dropped on the model, and then can be made to adjust to the model size.
CADwiesel
Besucht uns im CHAT
Proxy
Stateless-DHCP v6-Paketfragmentierer
Sehen Sie sich das Profil von Proxy an!   Senden Sie eine Private Message an Proxy  Schreiben Sie einen Gästebucheintrag für Proxy
Tastaturen, Mäuse,
Pladden, Monitore, ...
erstellt am: 05. Dez. 2004 13:41    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für CADwiesel 10 Unities + Antwort hilfreich
[...] the features that might appear in[...] => also einfach warme Luft. Mehr Infos
"Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?"  Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF
