Hallo Foamers,
Ich habe folgendes Problem: bei der Simulation von zwei Region (KK für Kühlkörper und bottomAir) nach Konvektion bekomme ich ständig die folgende Fehlermeldung:
| \\ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0
Exec : chtMultiRegionSimpleFoam
Date : Aug 09 2013
Time : 13:30:00
Host : "gpi12175.iavgroup.local"
PID : 13403
Case : /usr2/bottomAir_KK/case
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region bottomAir for time = 0
Create solid mesh for region KK for time = 0
*** Reading fluid mesh thermophysical properties for region bottomAir
Adding to thermoFluid
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Adding to rhoFluid
Adding to UFluid
Adding to phiFluid
Adding to gFluid
Adding to turbulence
Selecting turbulence model type laminar
Adding to ghFluid
Adding to ghfFluid
Radiation model not active: radiationProperties not found
Selecting radiationModel none
Adding fvOptions
No finite volume options present
*** Reading solid mesh thermophysical properties for region KK
Adding to thermos
type heSolidThermo;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
Adding to radiations
Selecting radiationModel opaqueSolid
Selecting absorptionEmissionModel constantAbsorptionEmission
Selecting scatterModel none
Adding fvOptions
Time = 1
Solving for fluid region bottomAir
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.024221, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0239137, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0235421, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0182296, No Iterations 3
Min/max T:294.282 300.428
GAMG: Solving for p_rgh, Initial residual = 0.841536, Final residual = 0.00288963, No Iterations 6
time step continuity errors : sum local = 0.0554715, global = 2.33029e-18, cumulative = 2.33029e-18
Min/max rho:1.15697 1.18114
Solving for solid region KK
DICPCG: Solving for h, Initial residual = 1, Final residual = 0.0205543, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 296.988 max(T) [0 0 0 1 0 0 0] 360
ExecutionTime = 1.8 s ClockTime = 2 s
Time = 2
DILUPBiCG: Solving for Ux, Initial residual = 0.492912, Final residual = 0.0174365, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.197266, Final residual = 0.01101, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.488943, Final residual = 0.0202762, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.426496, Final residual = 0.0100866, No Iterations 3
Min/max T:294.424 307.628
GAMG: Solving for p_rgh, Initial residual = 0.970015, Final residual = 0.00411204, No Iterations 7
time step continuity errors : sum local = 0.0211098, global = -2.13654e-18, cumulative = 1.93753e-19
Min/max rho:1.1284 1.18805
DICPCG: Solving for h, Initial residual = 0.209534, Final residual = 0.00386809, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 296.966 max(T) [0 0 0 1 0 0 0] 360
ExecutionTime = 2.47 s ClockTime = 3 s
Time = 3
DILUPBiCG: Solving for Ux, Initial residual = 0.471824, Final residual = 0.0371552, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.521667, Final residual = 0.0517465, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.470758, Final residual = 0.0320942, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.479107, Final residual = 0.0243738, No Iterations 2
Min/max T:248.206 316.052
GAMG: Solving for p_rgh, Initial residual = 0.717735, Final residual = 0.00578444, No Iterations 6
time step continuity errors : sum local = 0.0474212, global = 1.31978e-18, cumulative = 1.51353e-18
Min/max rho:0.859353 1.66003
DICPCG: Solving for h, Initial residual = 0.109024, Final residual = 0.00190127, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 296.863 max(T) [0 0 0 1 0 0 0] 360
ExecutionTime = 3.05 s ClockTime = 3 s
Time = 4
DILUPBiCG: Solving for Ux, Initial residual = 0.423113, Final residual = 0.0375891, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.725986, Final residual = 0.0713627, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.420529, Final residual = 0.0279138, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.710462, Final residual = 0.0287826, No Iterations 2
Min/max T:-687.938 321.57
GAMG: Solving for p_rgh, Initial residual = 0.791067, Final residual = 0.00474987, No Iterations 5
time step continuity errors : sum local = 0.113992, global = -7.09645e-19, cumulative = 8.03888e-19
Min/max rho:0.2 2
DICPCG: Solving for h, Initial residual = 0.0719346, Final residual = 0.00125857, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 295.145 max(T) [0 0 0 1 0 0 0] 360
ExecutionTime = 3.64 s ClockTime = 4 s
Time = 5
DILUPBiCG: Solving for Ux, Initial residual = 0.348038, Final residual = 0.0172571, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.480059, Final residual = 0.0462242, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.363602, Final residual = 0.0222914, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.446784, Final residual = 0.0196146, No Iterations 2
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
in file /usr2/sw/OpenFOAM//OpenFOAM-2.2.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
FOAM aborting
#0 Foam::error: rintStack(Foam::Ostream&) in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy>::*)(double) const) const in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#3 Foam::heRhoThermo<Foam::rhoThermo, Foam: ureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#4 Foam::heRhoThermo<Foam::rhoThermo, Foam: ureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam: erfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
#5
in "/cax/sw/OPENFOAM/LINUX_x86_64/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#6 __libc_start_main in "/lib64/libc.so.6"
#7
____________________________________________________________________________________________________________________
Dabei ist es klar zu sehen, dass der Konvergenz von h in der Luft instabil ist(Sehe Bild). Der Grund dafür habe ich nach mehrere Versuche indem ich viel BC benutzt, Relaxationfaktor geändert, div Scheme geändert, andere Netz benutzt... immer noch nicht gefunden.
Hier sind die 0-Ordner und system-Ordner Dateien:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 8.24e-7;
boundaryField
bottomMinX
type compressible::epsilonWallFunction;
value uniform 8.24e-7;
bottomMinY
bottomMinZ
bottomMaxX
bottomMaxY
bottomMaxZ
bottomAir_to_KK
FoamFile
version 2.0;
format ascii;
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 3.75e-5;
boundaryField
bottomMinX
type compressible::kqRWallFunction;
value uniform 3.75e-5;
bottomMinY
bottomMinZ
bottomMaxY
bottomMaxX
bottomMaxZ
bottomAir_to_KK
FoamFile
version 2.0;
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1e5;
boundaryField
bottomMinX
type calculated;
value uniform 1e5;
bottomMinY
type calculated;
value uniform 1e5;
bottomMinZ
type calculated;
value uniform 1e5;
bottomMaxY
type calculated;
value uniform 1e5;
bottomMaxX
type calculated;
value uniform 1e5;
bottomMaxZ
type calculated;
value uniform 1e5;
bottomAir_to_KK
type calculated;
value uniform 1e5;
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
bottomMinX
type fixedFluxPressure;
value uniform 1e5;
bottomMinY
value uniform 1e5;
bottomMinZ
value uniform 1e5;
bottomMaxX
value uniform 1e5;
bottomMaxY
value uniform 1e5;
bottomMaxZ
value uniform 1e5;
bottomAir_to_KK
value uniform 1e5;
FoamFile
version 2.0;
format binary;
location "1";
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 297;
boundaryField
bottomMinX
type zeroGradient;
bottomMinY
type zeroGradient;
bottomMinZ
type zeroGradient;
bottomMaxX
type zeroGradient;
bottomMaxY
type zeroGradient;
bottomMaxZ
type zeroGradient;
bottomAir_to_KK
type compressible::turbulentTemperatureCoupledBaffleMixed;
value uniform 297;
neighbourFieldName T;
kappa fluidThermo;
kappaName none;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0 -0.1 0 );
boundaryField
bottomMinX
type fixedValue;
value uniform (0 0 0);
bottomMinY
type fixedValue;
bottomMinZ
type fixedValue;
bottomMaxX
type fixedValue;
bottomMaxY
type fixedValue;
bottomMaxZ
type fixedValue;
bottomAir_to_KK
type fixedValue;
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(phi,K) bounded Gauss upwind;
div(phi,h) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear uncorrected;
laplacian(Dp,p_rgh) Gauss linear uncorrected;
laplacian(alphaEff,h) Gauss linear uncorrected;
laplacian(DkEff,k) Gauss linear uncorrected;
laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
laplacian(DREff,R) Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
fluxRequired
default no;
p_rgh;
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
rho
solver PCG
preconditioner DIC;
tolerance 1e-7;
relTol 0;
p_rgh
solver GAMG;
tolerance 1e-7;
relTol 0.01;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
"(U|h|k|epsilon)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-7;
relTol 0.1;
SIMPLE
momentumPredictor on;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 100000;
rhoMin rhoMin [1 -3 0 0 0] 0.2;
rhoMax rhoMax [1 -3 0 0 0] 2;
relaxationFactors
fields
rho 1;
p_rgh 0.3;
equations
U 0.7;
h 0.7;
nuTilda 0.7;
k 0.3;
epsilon 0.3;
omega 0.7;
"ILambda.*" 0.7;
Falls dass jemand eine Idee hat woran könnte es liegen, dass meine Berechnung immerwieder abstürtzt. Bitte Bitte mitteilen.
Ich bedanke mich im voraus.
