  ELCAD
  Export ELCAD 7.3 Project to ePlan 1.8.5
Maximale Betriebseffizienz: Aker BP setzt beim Yggdrasil-Projekt auf Aucotec, eine Pressemitteilung
Autor Thema:  Export ELCAD 7.3 Project to ePlan 1.8.5 (3795 mal gelesen)
padfoot
Sehen Sie sich das Profil von padfoot an!   Senden Sie eine Private Message an padfoot  Schreiben Sie einen Gästebucheintrag für padfoot
erstellt am: 03. Jun. 2013 08:19    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
ELC2EPL.txt
Hello
I'm sorry for typing in English here.
I've created a topic in ePlan section, but I realized that my problem is an ELCAD problem not ePlan!
So I'll copy my posts here.
ePlan topic:
http://ww3.cad.de/foren/ubb/Forum467/HTML/007050.shtml
I've searched the web to find a solution for my problem but had no luck.
The only forum that was close to my problem is here!
So, I'll be grateful if you help me.
I have no problem with answers in German. So just answer my question please.
I want to export an ELCAD 7.3 project and import it to ePlan 1.8.5.
I've read ELCAD help and follow these instructions:
- Go to the menu: Extras -> Services -> EPL Write
- Target Drive/Path: d:/eplan4/p/elc2epl
- Target Project: master
- Path of CFG Data: C:/Program Files/Elcad 7.3/USR/AUCO.73
- Name of CFG File: elc2epl
- CFG File: CFG
- OK
- Then Batch Proccess will begin.
ELCAD help says:
Data created:
The EPL write processor automatically generates the following directory structure in the specified drive:
--EPLAN4
+--N
¦ +--ELC2EPL
¦ +--MUSTER
+--P
+--ELC2EPL
+--MUSTER.P
The directory d:\eplan4\n\elc2epl\master contains the "normal master files" of the converted project. This includes among other things the symbol files and the plot frames.
There the symbol files:
AELCAD.SYM
Moreover the directory contains all of the plot frames used in the project: xxxxyyyy.SKG
The directory d:\eplan4\p\elc2epl\muster.p contains the EPLAN project data.
But in this case, the folder "d:\eplan4\n\elc2epl\master" is empty and just some small files created in this path:
D:\eplan4\p\elc2epl\master.P
I could not find symbols file or frame file or project file or anything!
Should I rename the file extension?
Also, I attached the log file of ELCAD conversion.
Does anyone convert a project like this?
What should I do?
Thank you for your help.
PS:
Thanks to "Google Translate", I can read your posts in German or any other languages!
[Diese Nachricht wurde von padfoot am 03. Jun. 2013 editiert.]
