  Solid Edge
  Solid Edge V12 Servicepack 4
SPOT-ON: Der Struktur-Designer in NX CAD, ein Webinar am 20.11.2026
Autor Thema:  Solid Edge V12 Servicepack 4 (1055 mal gelesen)
kmw
erstellt am: 17. Nov. 2002 00:17    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Kaum haben auch nur annähernd alle das Servicepack 3 für die V12 verdaut (sofern die V12 überhaupt schon im Einsatz ist) da steht schon wieder ein neues Servicepack zur Verfügung:
November 15, 2002
Dear Solid Edge Customer:
We are pleased to announce the availability of Solid Edge V12 Update 4.
Update 4 addresses issues reported by Solid Edge customers. We appreciate your continued business and your participation in the software support process -- your reporting helps us make Solid Edge a more productive CAD system for the way you do business. Thanks for your interest in Solid Edge, and for continuing feedback on this Update. Please contact us if we can assist you in any way.
Sincerely,
The Solid Edge Team
For current information about Solid Edge, as well as, announcements, software updates, and User Group activities, please visit our web sites www.solidedge.com and support.plms-eds.com.
Download Size: 98MB
Steps to Download via FTP:
FTP to ftp.plms-eds.com (enter WebKey login and password)
ftp> cd solid_edge/solid_edge/ver12/Update4
ftp> cd English, German, etc.
ftp> set bin
ftp> get seupdate.exe
Steps to Download via HTTP:
- Open http://ftp.plms-eds.com/
- Enter your WebKey Account
- Select solid_edge
- Select ver12
- Select Update4
- Select desired language, English, German, etc.
- Select seupdate.exe
- Select download location.
If you are unable to download Solid Edge V12 Update 4, CDs will be available from Distribution Services. North American Customers see details below. International Customers contact your local EDS PLM Solutions office or Reseller to request a CD.
Erfolgreiches Saugen !
Gruß Klaus
Solid Edge Hotline:
Tel: +49 (07031)-754565
solidedge@sstonline.de
kmw
erstellt am: 17. Nov. 2002 00:41    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
achja, wie ich schon mal bereits erwähnte, ein download wird sicher länger dauern, wenn man montags morgens, gemeinsam mit allen anderen in Deutschland versucht zu saugen.
.. ich hab meinen in kürzester Zeit mit satten 90kb/sek schnell erledigt.. 18 Min. 30 Sek !
So morgens, 0:39 Uhr.
sorry, aber ich konnte mir diesen Hinweis nicht verkneifen.
Gruß Klaus
Lars
Solid Edge
erstellt am: 17. Nov. 2002 22:03    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für kmw 10 Unities + Antwort hilfreich
besser viele nacheinander als keine, oder?
aber die performance ist echt "spitze"
grüße
Lars
Trebusch
Sehen Sie sich das Profil von Trebusch an!   Senden Sie eine Private Message an Trebusch  Schreiben Sie einen Gästebucheintrag für Trebusch
erstellt am: 18. Nov. 2002 13:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für kmw 10 Unities + Antwort hilfreich
Also ich hoffe, unter 2 Stunden (T-DSL) bleiben zu können :-)
Stört mich aber nicht, es bracht je keine Aufsicht....
StephanWeber
Dipl. Ing.
Sehen Sie sich das Profil von StephanWeber an!   Senden Sie eine Private Message an StephanWeber  Schreiben Sie einen Gästebucheintrag für StephanWeber
Pentium 4 3,05 Ghz, 1,0 Gb Speicher 800 HhZ RIMM, FX 5900, Dell 2000 fp / Belinea
erstellt am: 18. Nov. 2002 18:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für kmw 10 Unities + Antwort hilfreich
könnte mal jemand berichten, welche Bugs da gefixt wurden?
Dann kann man sich überlegen, ob sich der Download lohnt
Stephan
Markus Gras
Solid Edge AE
Kritik muß sachlich falsch und persönlich verletzend sein, damit sie wirkt.
erstellt am: 19. Nov. 2002 09:37    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für kmw 10 Unities + Antwort hilfreich
Hallo Stephan,
das ReadMe steht auch zum Download bereit.
Es hat eine Größe von 4KB und enthält zu allen gefixten Calls, auch die PR Nummer.
Aber vorsicht! - Das ReadMe steht nicht in den Länderspezifischen Verzeichnissen, sondern auf gleicher Ebene wie diese.
Was diesmal dazugekommen sein soll, ist das die ProE Schnittstelle nun auch die aktuellen Versionen lesen kann.
Das ging bisher nur bis ProE V20, da die höheren Versionen wohl irgendwie codiert wurden.
Markus Gras
