  Creo Elements/Direct
  [English] read part property
Autor Thema:  [English] read part property (1946 mal gelesen)
cacciatorino
Sehen Sie sich das Profil von cacciatorino an!   Senden Sie eine Private Message an cacciatorino  Schreiben Sie einen Gästebucheintrag für cacciatorino
Solid Edge ST10 Win10-64
Modeling V20.5 Win10-64
Salome 9.1
erstellt am: 12. Apr. 2015 18:24    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
load_bom_file.lsp
Hallo to all!
I have an assembly that belongs to my customer. Parts and subassembly have metadata written in the model, so I'm trying to use them to create my BOM list to be inserted in Annotation. I have two kind of property in each file: the first ones have the symbols ":" as pre-text before the property name, the second ones have the property name written inside commas:
Code:
Part/Assy = /g1/VITE_UNI5739_M16x65.2.1.1.4.1
Instance Attributes
Contents Attributes
(DB-PREF)
    :FILING =  :MI-FILE
    :FILING =  :SD-FILE
    :ON-COPY =  :MAINTAIN
    :ON-XFORM =  :MAINTAIN
    :ON-SYSID-CHANGE =  :MAINTAIN
    :ON-MERGE =  :DETACH
    :ON-SPLIT =  :MAINTAIN
    "isi_stato_cod" =  "3"
    "isi_codice" =  "K270445"
    "isi_data_stato" =  "2006/11/20 13:43:10 +01:00"
    :ELID =  "61400"
    "isi_data_aggiornamento" =  "2012/07/20 16:26:03 +02:00"
    :UNIQUE_ID_STRING =  "K270445"
    :RICAMBIO =  "-"
    :VERSION =  "0"
    "id_elemento" =  "61400"
    "isi_descrizione" =  "VITE_UNI5739_M16x65"
    etc
    etc
I modified the macro provided in the on-line help, as follows:
Code:
(defun bomattr-get-descrizione (selitem)
  (let ((attr (sd-inq-item-attribute selitem "DB-PREF"
                                     :values :attachment :contents)))
     (if attr (getf attr :DENOMINAZIONE) nil)
I was able to read the property of type :SOMETHING = "value" and insert it in my BOM, but I cannot find the way to read the property of type "something_else" = "other value".
Any help to obtain this?
[Diese Nachricht wurde von cacciatorino am 12. Apr. 2015 editiert.]
cacciatorino
Salome 9.1
erstellt am: 12. Apr. 2015 18:42    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
screw.pkg
Here comes a sample file.
One more question: is it possible to copy a part and make that the new part inherit all properties from her parent?
AlexG
Sehen Sie sich das Profil von AlexG an!   Senden Sie eine Private Message an AlexG  Schreiben Sie einen Gästebucheintrag für AlexG
Win7 64-bit; Intel Core
i7, 8CPUs @ 2,2GHz; 16GB
RAM; 120GB SSD; Nvidia
Quadro 1000 M;
SolidDesigner 18.0
erstellt am: 13. Apr. 2015 14:30    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für cacciatorino 10 Unities + Antwort hilfreich
it's possible for me to reproduce this problem. The result of sd-inq-item-attribute seems only to be partly a plist. All attributes using keywords are working as expected, but if the designator is a string it's not working and the value can't be inquiered...weired.
Here is a quick and dirty workaround, which works for me:
Code:
  (let* (
  (id-element-attrib (sd-inq-item-attribute selitem "DB-PREF" '("id_elemento") :attachment :contents))
  (id-element-designator (first id-element-attrib))
  (id-element-value (second id-element-attrib)))
  (display id-element-value)
Just for giving an inspiration: For copying attributes have look at sd-attach-item-attribute...
Best regards,
Alex
Computer sind unbrauchbar. Sie können nur Fragen beantworten.
Pablo Picasso, Maler
cacciatorino
Salome 9.1
erstellt am: 14. Apr. 2015 09:20    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Thank you very much for the valuable feedback, finally I got somethign working using this lisp:
Code:
(defun bomattr-get-isi_descrizione (selitem)
    (setf isi_descrizione (sd-inq-item-attribute selitem "DB-DREF" "isi_descrizione" :attachment :contents)
Bests regards, Alessandro.
[Diese Nachricht wurde von cacciatorino am 14. Apr. 2015 editiert.]
