  Heisse Eisen
  will auch mal starten ;o)
Autor Thema:  will auch mal starten ;o) (746 mal gelesen)
Bene
ich putz' hier nur
ich hatte mal Inventor...
erstellt am: 05. Nov. 2004 20:54    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat
UNIX Airways
Everyone brings one piece of the plane along when they come to the airport. They all go out on the runway and put the plane together piece by piece, arguing non-stop about what kind of plane they are supposed to be building.
Air DOS
Everybody pushes the airplane until it glides; then they jump on and let the plane coast until it hits the ground again. They then push again, jump on again, and so on...
Mac Airlines
All the stewards, captains, baggage handlers, and ticket agents look and act exactly the same. Every time you ask questions about details, you are gently but firmly told that you don't need to know, don't want to know, and everything will be done for you without your ever having to know, so just shut up.
Windows Air
The airport terminal is pretty and colorful, with friendly stewards, easy baggage check and boarding, and a smooth take-off. After about 10 minutes in the air the plane explodes with no warning whatsoever.
Windows NT Air
Just like Windows Air, but costs more, uses much bigger planes, and takes out all the other aircraft within a 40 mile radius when it explodes.
Linux Air
Employees of all the other OS airlines decide to run their own airline. They build the planes, ticket counters, and pave the runways themselves. They charge a small fee to cover the cost of printing the ticket, but you can also download and print the ticket yourself. When you board the plane you are given a seat, four bolts, a wrench and a copy of the seat-HOWTO.html. Once settled, the fully adjustable seat is very comfortable, the plane leaves and arrives on time without a single problem, the in-flight meal is wonderful. You try to tell customers of the other airlines about the great trip, but all they can say is "You had to do what with the seat?"
ciao bene
"Bloody Stupid Johnson"
smb
zu viele
erstellt am: 05. Nov. 2004 22:32    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat
....kann man nur hoffen, dass keine zum geistigen Tiefflieger
mutiert! ;-)
CUSee you = Wir sehen uns SMB
P.S.: Keine Anspielung! ;-)
"Es kann ja nicht immer regnen!"
"Opfer...sind wir das nicht alle?"
(Wer Rechtschreibfehler findet darf diese behalten!)
mtl3d
Sehen Sie sich das Profil von mtl3d an!   Senden Sie eine Private Message an mtl3d  Schreiben Sie einen Gästebucheintrag für mtl3d
Pro/E Wildfire 1, Acad ,Inventor
erstellt am: 08. Nov. 2004 22:29    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat
sach ich doch, Linux kommt wenigstens an, wenn man denn den Sitz zusammenbauen kann. Aber keine Angst spätestesn ach einigen Versuchen klappt es und man schwört drauf.
so long ...
Achim
"referenzierst Du noch oder konstruierst Du schon?"
[Diese Nachricht wurde von mtl3d am 08. Nov. 2004 editiert.]
