  CATIA V5 Programmierung
  FTA DrawingText repositioning
Autor Thema:  FTA DrawingText repositioning (910 mal gelesen)
Sylas
Sehen Sie sich das Profil von Sylas an!   Senden Sie eine Private Message an Sylas  Schreiben Sie einen Gästebucheintrag für Sylas
Dell Precision T3500
Intel Xeon W3550 @ 3,07 GHz
12 GB RAM
CATIA V5 R28
erstellt am: 17. Aug. 2023 09:15    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello Community!
I wrote a little macro to postion FTA text B in related position to FTA text A. It seems working, but somehow, it doesn't repeat it more then twice. Can someone tell me where have I made something wrong?
Basically what it does, it measures displacement between two positions and gives user the posibility (through form) to eiteh copy exact X/Y coordinate, or to add aditional offset. After clicking on X or Y it should ask user if she/he wants to repeat the process or end. And this is the point where it stops working as it should
Unfortunately, because of the privacy policy of my company - I can't upload a file - sorry
Please help me find the problem
Thanks in advacne
Lucas
Module code
Code:
Global oText_source As DrawingText
Global oText_target As DrawingText
Global X_Pos_S As Double
Global Y_Pos_S As Double
Global X_Pos_T As Double
Global Y_Pos_T As Double
Global coord As String
Sub CATMain()
'Dim oText_source As DrawingText
'Dim oText_target As DrawingText
Dim sName As String
Dim sNewName As String
Dim odSel As Selection
Dim oSel
Dim InputObjectType(0) As Variant
Set odSel = CATIA.ActiveDocument.Selection
odSel.Clear
Set oSel = odSel
InputObjectType(0) = "AnyObject"
Result = oSel.SelectElement2(InputObjectType, "Select source", True) '.SelectElement3(InputObjectType, "Wybierz źródło", True, CATMultiSelTriggWhenUserValidatesSelection, True)
Set oAnn_source = oSel.Item(1).Value
Set oText_source = oAnn_source.Text.Get2dAnnot
X_Pos_S = oText_source.X
Y_Pos_S = oText_source.Y
odSel.Clear
Result = oSel.SelectElement2(InputObjectType, "Select target", True) 'SelectElement3(InputObjectType, "Wybierz cel", True, CATMultiSelTriggWhenUserValidatesSelection, True)
Set oAnn_target = oSel.Item(1).Value
Set oText_target = oAnn_target.Text.Get2dAnnot
X_Pos_T = oText_target.X
Y_Pos_T = oText_target.Y
MsgBox ("Displacement in X:  " & Round(Abs(X_Pos_T - X_Pos_S), 0) & vbNewLine & "Displacement in Y:  " & Round(Abs(Y_Pos_T - Y_Pos_S), 0))
Pos_form.Show
If coord = "X" Then
    GoTo copying_X_postion
Else
    GoTo copying_Y_postion
End If
copying_X_postion:
oText_target.X = CDbl(X_Pos_S) + CDbl(Pos_form.X_Disp)
oAnn_target.ModifyVisu
GoTo replay
copying_Y_postion:
oText_target.Y = CDbl(Y_Pos_S) + CDbl(Pos_form.Y_Disp)
GoTo replay
replay:
test = MsgBox("Chciałbyś spróbować jeszcze raz?", vbYesNo, "Korekta")
If test = vbYes Then
    Pos_form.Show
Else
    GoTo update
End If
update:
MsgBox ("Gotowe!")
End Sub
Form code
Code:
Private Sub UserForm_Initialize()
Me.X_Source = Round(oText_source.X, 0)
Me.Y_Source = Round(oText_source.Y, 0)
End Sub
Private Sub X_Pos_Click()
Pos_form.Hide
coord = "X"
End Sub
Private Sub Y_Pos_Click()
Pos_form.Hide
coord = "Y"
End Sub
EDIT: Just noticed, I've double-posted  @admin - please remove the other post of FTA NOA displacement, or merge them together
[Diese Nachricht wurde von Sylas am 17. Aug. 2023 editiert.]
bgrittmann
CATIA V5R19
erstellt am: 17. Aug. 2023 10:57    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi Lucas
What should be repeated?
Where does it stops?
be aware: after test = vbYes  Pos_form.Show the script jumps to update:
regards,
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 17. Aug. 2023 12:17    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Original erstellt von bgrittmann:
Hi Lucas
be aware: after [i]test = vbYes  Pos_form.Show
regards,
[/i]
Hi Bernd
After user decides to "copy" the X (or Y) coordinate, the mesage (result) shuold pop up asking user if he/she wants to repeat the process (again for X or for Y coordinate).
I'm wondering, why does it not work that way...
Best regards
Lucas
bgrittmann
CATIA V5R19
erstellt am: 17. Aug. 2023 12:48    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi
I suggest to set a breaking point and run your code step wise.
Your Userform does not call your code in the CATMain again
Regards,
PS: GoTo is not used very often in vba, because the code is hard to read/trace
