  CATIA V5 Programmierung
  Allcatpart
Autor Thema:  Allcatpart (1069 mal gelesen)
Sylas
Sehen Sie sich das Profil von Sylas an!   Senden Sie eine Private Message an Sylas  Schreiben Sie einen Gästebucheintrag für Sylas
Dell Precision T3500
Intel Xeon W3550 @ 3,07 GHz
12 GB RAM
CATIA V5 R28
erstellt am: 11. Jul. 2023 12:09    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello Gals & Gents!
I'm trying to write a macro to create allcatpart from a Product, reset its Properties (like Reset Properties function under RMB) and set all edges to black, and all bodies to sand brown). I already have written this:
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "CATPrtSearch.MechanicalFeature,all"
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetRealColor 211, 178, 125, 1 'rgba(211,178,125,255)
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetRealOpacity 255, 1
selection1.Clear
selection1.Search "CATAsmSearch.Part,all"
selection1.Clear
selection1.Search "((((((FreeStyle.Curve + '2D Layout for 3D Design'.Curve) + Sketcher.Curve) + Drafting.Curve) + 'Part Design'.Curve) + 'Generative Shape Design'.Curve) + 'Functional Molded Part'.Curve),all"
If selection1.Count <> 0 Then selection1.Delete
selection1.Clear
selection1.Search "(((FreeStyle.'Geometrical Set' + 'Part Design'.'Geometrical Set') + 'Generative Shape Design'.'Geometrical Set') + 'Functional Molded Part'.'Geometrical Set'),all"
    Dim oGS As HybridBody
    Dim oCol As New VBA.Collection
    For i = 1 To selection1.Count
    Set oGS = selection1.Item(i).Value
    If oGS.HybridShapes.Count = 0 And oGS.HybridBodies.Count = 0 Then
        oCol.Add oGS
    End If
    Next
    selection1.Clear
    If oCol.Count <> 0 Then
        For j = 1 To oCol.Count
            selection1.Add oCol.Item(j)
        Next
        selection1.Delete
    End If
End If
selection1.Clear
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
viewer3D1.Reframe
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
MsgBox ("Done!")
End Sub
but it seems not to change edges of the bodies (some stay with original colors). Can anyone tell me what am I doing wrong?
When I manually search for the edges (by CTRL+F and choosing "from selection") it says I'm pointing PartDesign Feature (I'm pointing on  isolated solid's edge)
Thanks in advance
Lucas
bgrittmann
CATIA V5R19
erstellt am: 11. Jul. 2023 12:19    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi Lucas
Can you please post a picture of your wrong colored part?
Are in these parts only bodies or also surfaces?
Have you (manual) tried to apply the color onto the bodies?
Regards,
PS: please also check https://ww3.cad.de/foren/ubb/Forum137/HTML/002144.shtml#000014
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 12. Jul. 2023 09:25    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello Bernd
As I wrote, I can easily reset body color, but edges stay with original color (see middle of the picture). Mostly, my parts are having just bodies, but in some cases, there could be surfaces too.
bgrittmann
CATIA V5R19
erstellt am: 12. Jul. 2023 17:00    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi
You can try to change the settings of the color management, so colors are not transferred during copying. (Infrastructure -> Part Infrastructure -> Part Document)
Regards,
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 12. Jul. 2023 19:55    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi Bernd
I don't mind half transparent body colors. Edges of the bodies are sometimes white (in cases, when original color of the body is black, apparently to make them visible somehow). But I need to set each body (in other words: face) sand brown, and each edge black again. I hope this clears my needs
Best regards
Lucas
bgrittmann
CATIA V5R19
erstellt am: 12. Jul. 2023 20:19    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi Lucas
That is clear to me.
I my short test, I did not manage to color the edges by a macro.
Regards,
tomtom1972
dipl ing maschinenbau
Sehen Sie sich das Profil von tomtom1972 an!   Senden Sie eine Private Message an tomtom1972  Schreiben Sie einen Gästebucheintrag für tomtom1972
NVidia Quadro K4000
Intel Xeon E5-1620, 64GB RAM
Windows10 64bit
R30 <= CATIA V5 > =R19
erstellt am: 14. Jul. 2023 08:10    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Sylas 10 Unities + Antwort hilfreich
Hi Sylas,
try this:
https://ww3.cad.de/foren/ubb/Forum137/HTML/002144.shtml#000023
After that, everything should be colorable normally.
BR TomTom
tomtom1972
Sylas
12 GB RAM
CATIA V5 R28
erstellt am: 14. Jul. 2023 14:07    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi
OMG that looks too complicated for me
It looks like it wasn;t updated after last comment, and my coding knowledge is to small for that, I'm afraid
Best regards
Sylas
