  Availability of CATIA/ENOVIA/SMARTEAM V5R14sp2
Autor Thema:  Availability of CATIA/ENOVIA/SMARTEAM V5R14sp2 (580 mal gelesen)
Axel.Strasser
Selbstständig im Bereich PLM/CAx
Sehen Sie sich das Profil von Axel.Strasser an!   Senden Sie eine Private Message an Axel.Strasser  Schreiben Sie einen Gästebucheintrag für Axel.Strasser
Früher war vieles gut, und das wäre es heute immer noch, wenn man die Finger davon gelassen hätte!
erstellt am: 03. Dez. 2004 08:30    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
As of 02 December 2004, the following are available for ordering at URL:
  http://techsupport.services.ibm.com/engineering/catia.orderpmpfixes
        SP01402 - AIX
        SP11402 - HP-UX
        SP21402 - IRIX
        SP31402 - Solaris
        SP51402 - Windows2000/XP
In addition to the above, the following is available for downloading at URL:
  http://techsupport.services.ibm.com/engineering/catia.dlpmpfixes
        SP91402 - SMARTEAM on Windows
For further information, review the Program Directories available at URL:
  http://techsupport.services.ibm.com/engineering/duke?fetch=/PD/index.html
Special Notes:
1) SMARTEAM on Windows
  During the installation:
  - The progress bar will show R13SP6.
    You can ignore the incorrrect text of this informational message.
  - If installing from CDs (as opposed to a server), you will be asked to
    insert V5R14SP1. As SP1 was included in the GA, you must insert the
    V5R14GA CD, instead.
  Very few copies of SP2 were delivered from the IBM distribution centers
  before 24 November. If you were to use such a CD instead of the ones
  currently being delivered, the following errors might occur:
  - User requested to insert R13SP6 CD instead of R14GA/SP1 CD
  - Inability to remove SmartBOM product after the installation
  - Wrong version number on the SmartBOM  been included in the GA
  - A second installation of SmarTeam R14 SP2 fails to recognize SmartBOM
2) CAA API AIX 32 and 64 bit
  Via CD-ROM, CAA API cannot be installed on AIX 32 bit workstation or
  servers. It can, however, be installed on AIX 64 bit machines and all
  other supported UNIX machines because the installation procedure on the
  CDs is the 64 bit version which is not runnable on a 32 bit machine.
  Bypasses:
  - Run the installation on a AIX 64 bit machine, or
  - Run the installation on another UNIX workstation and mount the
    directory where you install the CAA API on the AIX 32 bit machine on
    which you wish to develop.
3) In Catia V5R14, it is no longer possible to create a new sheetmetal part
  in the Sheetmetal Design workbench. The user is notified to use the
  Generative Sheetmetal Design workbench instead. The Sheetmetal Design
  workbench can still be used for edition and modification of any existing
  sheetmetal parts previously created within this workbench.
*  If you have comments/questions about this flash or if you do not wish to
*  receive future informational flashes, PLEASE DO NOT RESPOND TO THIS NOTE
*  as it was sent by a service machine. Rather, use the following link to
*  access the FEEDBACK form on our web site and contact us directly:
*      http://techsupport.services.ibm.com/engineering/feedback
