Thema: ProTollkit linken für VS .NET 2003 (611 mal gelesen)
chriszf Mitglied
 Beiträge: 3 Registriert: 14.12.2006
erstellt am: 14. Dez. 2006 11:14 <-- editieren / zitieren --> Unities abgeben:
Hallo, ich versuche Protoolkit in Visual Studio .NEt 2003 zu linken, aber das will nicht. Ich habe diese Anleitung befolgt aber kriege jetzt die folgenden Fehlermeldungen: warning LNK4017: DESCRIPTION statement not supported for the target platform; ignored HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol ___mb_cur_max HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2001: unresolved external symbol __pctype HRG_ProEngineer_project error LNK2019: unresolved external symbol ___mb_cur_max referenced in function _pfa_is_local HRG_ProEngineer_project error LNK2019: unresolved external symbol ___mb_cur_max referenced in function _pfafs_open_low HRG_ProEngineer_project error LNK2019: unresolved external symbol ___mb_cur_max referenced in function _set_ugc_mb_lang_env HRG_ProEngineer_project error LNK2019: unresolved external symbol ___mb_cur_max referenced in function _strip_redund_whitespace HRG_ProEngineer_project error LNK2019: unresolved external symbol __pctype referenced in function _pfa_chdir HRG_ProEngineer_project error LNK2019: unresolved external symbol __pctype referenced in function _pfafs_open_low HRG_ProEngineer_project error LNK2019: unresolved external symbol __pctype referenced in function _set_ugc_mb_lang_env HRG_ProEngineer_project error LNK2019: unresolved external symbol __pctype referenced in function _strip_redund_whitespace HRG_ProEngineer_project error LNK2019: unresolved external symbol __sys_nerr referenced in function _clnt_sperror HRG_ProEngineer_project error LNK2019: unresolved external symbol _errno referenced in function _bindresvport HRG_ProEngineer_project error LNK2019: unresolved external symbol _errno referenced in function _change_state HRG_ProEngineer_project error LNK2019: unresolved external symbol _errno referenced in function _dbg_comp_two_files_search HRG_ProEngineer_project error LNK2019: unresolved external symbol _errno referenced in function _get_nt_drive_info HRG_ProEngineer_project error LNK2019: unresolved external symbol _errno referenced in function _pfu_copy_ext HRG_ProEngineer_project fatal error LNK1120: 4 unresolved externals HRG_ProEngineer_project warning LNK4075: ignoring '/INCREMENTAL' due to '/OPT:ICF' specification Kann mir jemand helfen? *seufz* -Chriszf [Diese Nachricht wurde von chriszf am 14. Dez. 2006 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
roltermann Mitglied
 Beiträge: 61 Registriert: 05.01.2001 Dell M65 / Pro/E 2001-WF4
erstellt am: 14. Dez. 2006 11:57 <-- editieren / zitieren --> Unities abgeben:          Nur für chriszf
Moin, hast Du die Beispiele verwendet die auf der Seite sind oder bist Du die Schritte an einem eigenen Projekt durchgegangen? Sync oder async? ------------------ Gruß, Ralf [Diese Nachricht wurde von roltermann am 14. Dez. 2006 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
chriszf Mitglied
erstellt am: 14. Dez. 2006 12:09 <-- editieren / zitieren --> Unities abgeben:
Moin Moin, Ich habe es versucht mit den beispielen auf der Seite (in den beiden ZIP-files) und mit meinem Projekt das asynchron sein soll (daher kommen die fehlermeldungen), und kriege in jedem fall linking errors. Ich habe noch etwas gegooglet und dieses Tutorial gefunden, das neuer ist und in dem zu anderen Libraries gelinkt wird. Ausserdem ist dieses wirklich für Dummies, müsste also laufen  Das werd ich erstmal versuchen und wenn's nicht klappt nochmal nachfragen hier. Danke auch! Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
chriszf Mitglied
erstellt am: 14. Dez. 2006 12:56 <-- editieren / zitieren --> Unities abgeben:
Mit dem neueren Tutorial kriege ich diese Fehlermeldungen: warning LNK4017: DESCRIPTION statement not supported for the target platform; ignored warning C4101: 'buf' : unreferenced local variable HRG_ProEngineer_project error LNK2005: "private: __thiscall type_info::type_info(class type_info const &)" (??0type_info@@AAE@ABV0@@Z) already defined in libc.lib(typinfo.obj) HRG_ProEngineer_project error LNK2005: "private: class type_info & __thiscall type_info: perator=(class type_info const &)" (??4type_info@@AAEAAV0@ABV0@@Z) already defined in libc.lib(typinfo.obj) HRG_ProEngineer_project error LNK2005: "public: __thiscall bad_cast::bad_cast(char const *)" (??0bad_cast@@QAE@PBD@Z) already defined in libc.lib(stdexcpt.obj) HRG_ProEngineer_project fatal error LNK1169: one or more multiply defined symbols found HRG_ProEngineer_project warning LNK4006: "private: __thiscall type_info::type_info(class type_info const &)" (??0type_info@@AAE@ABV0@@Z) already defined in libc.lib(typinfo.obj); second definition ignored HRG_ProEngineer_project warning LNK4006: "private: class type_info & __thiscall type_info: perator=(class type_info const &)" (??4type_info@@AAEAAV0@ABV0@@Z) already defined in libc.lib(typinfo.obj); second definition ignored HRG_ProEngineer_project warning LNK4006: "public: __thiscall bad_cast::bad_cast(char const *)" (??0bad_cast@@QAE@PBD@Z) already defined in libc.lib(stdexcpt.obj); second definition ignored HRG_ProEngineer_project warning LNK4075: ignoring '/INCREMENTAL' due to '/OPT:ICF' specification HRG_ProEngineer_project warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library Gibt es eigentlich keine offiziellen Tutorials/ Beispiele für Visual Studio direkt von PTC? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
roltermann Mitglied
erstellt am: 15. Dez. 2006 13:48 <-- editieren / zitieren --> Unities abgeben:          Nur für chriszf
Hi, die offizielle Vorgehensweise ist es den Compiler vom VS.Net 2003 mit den mitgelieferten makefiles zu verwenden. Soll heißen Du kannst die VS IDE zwar zum editieren verwenden solltest aber zum übersetzen die makefile nutzen. Oder Du liest mal die makefiles genau und trägst alle Einstellungen ins VS ein. Gruß Ralf ------------------ Gruß, Ralf Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
