  Change of I-deas
Autor Thema:  Change of I-deas (500 mal gelesen)
Harald Lüling
Sehen Sie sich das Profil von Harald Lüling an!   Senden Sie eine Private Message an Harald Lüling  Schreiben Sie einen Gästebucheintrag für Harald Lüling
erstellt am: 02. Mai. 2004 06:58    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Anybody knows an actual test which compares the performance of different CAD programs like I-deas, NX 2, Solid Edge V15 and Catia V5?
Today we are using I-deas NX and testing Unigraphics NX 2.
When we change to another system the iterative design improvement process on _(complex) 3D objects_ shall be more efficient (quick, easy). The rest of I-deas is very fine.
More detailled information about our problems:
I am not satisfied with the stability and performance of the algorithms of I-deas NX and NX 2 when changing draft angles, rounds, fillets, lofts, ...
Problems arise when the optical design of a part is ready and it is then necessary to change geometry add draft angles, ... for diecasting or plasic injection purposes. In most cases it is necessary to rebuild many of the rounds, fillets, ...
I have no idea if Pro ENGINEER has a better performance and stability in this area.
Thank you for hints! (deutsch oder/or english)
Regards
Harald
