  ANSYS
  Rigid Body Motion/Residual below of convergence in ansys APDL 14.5
Entwicklungsingenieurin trifft KI-Experten, eine Pressemitteilung
Autor Thema:  Rigid Body Motion/Residual below of convergence in ansys APDL 14.5 (2493 mal gelesen)
Bruce321
Sehen Sie sich das Profil von Bruce321 an!   Senden Sie eine Private Message an Bruce321  Schreiben Sie einen Gästebucheintrag für Bruce321
erstellt am: 08. Jan. 2015 00:41    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Input.txt
Hi all,
I am analysing a 2D D-shaped Neo Hookean model in contact with a Rigid link. The details are as written below and also the input file is attached.
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
/GO
/PREP7
ET,1,PLANE183
KEYOPT,1,1,0
KEYOPT,1,3,2
KEYOPT,1,6,0
ET,2,MPC184
KEYOPT,2,1,0
KEYOPT,2,2,1
TB,HYPE,1,1,1,NEO
TBDATA,1,2.808e6,0,
MP,DENS,1,1195,
MP,ALPX,2,
MP,DENS,2,0
BLC4,0,0.05,0.05,-0.1
CYL4,0.05,0,0.05,90,0,-90
AADD,1,2
BLC4,0.025,0.025,0.025,-0.05
CYL4,0.05,0,0.025,90,0,-90
AADD,1,2
ASBA,3,4
MOPT,QMESH,MAIN
ASEL,,AREA,,1,,,1
AATT,1,,1,0,
CM,S1,LINE
LESIZE,S1,0.001
AMESH,1
K,9,0.1,0,0
K,10,0.1,0.05,0
K,11,0.1,-0.05,0
L,9,10
L,9,11
LSEL,S,,,5,
LSEL,A,,,9,
LATT,2,,2,
SMRT,1
LSEL,S,LINE,,5,
LSEL,A,LINE,,9,
LESIZE,ALL,0.001
LMESH,ALL
LSEL,NONE
LSEL,ALL
LREVERSE,5,0
/COM,
REAL,3
ET,3,169
ET,4,172
KEYOPT,4,4,2
KEYOPT,4,5,3
KEYOPT,4,6,2
KEYOPT,4,9,3
KEYOPT,4,10,2
KEYOPT,4,12,4
LSEL,S,,,5
LSEL,A,,,9
CM,S2,LINE
TYPE,3
NSLL,S,1
ESLN,S,0
ESURF
LSEL,S,,,8
TYPE,4
NSLL,S,1
ESLN,S,0
ESURF
ESEL,ALL
ALLSEL
EPLOT
/SOLN
ANTYPE,0
NLGEOM,ON
NSUBST,25,25,10
DL,4,,UY,
DL,4,,UX,0.001
When I am solving this I am getting errors as Rigid Body motion/ Residual below of convergence criteria. Please help me!!!!!!!!!!!!
Vielen Dank schon im Voraus!
arnd13
Dipl. Ing.
Sehen Sie sich das Profil von arnd13 an!   Senden Sie eine Private Message an arnd13  Schreiben Sie einen Gästebucheintrag für arnd13
erstellt am: 08. Jan. 2015 09:50    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Bruce321 10 Unities + Antwort hilfreich
Hi Bruce,
Without digging too much into the model, I can only spot fixations in x and y direction. Therefore rigid body motion in z direction is not contraint.
You may want to perform a modal analysis with the model to find out, which part is "flying" and where.
Gruß, A.
Bruce321
erstellt am: 08. Jan. 2015 16:47    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Thank you Arnd. I did fix the model in Z direction and fixed the rigid beam in XYZ directions but the problem which I am facing now is residual convergence criteria below the required value. Can you please look into it in detail and please help me on this.
Regads,
Bruce
arnd13
Dipl. Ing.
erstellt am: 08. Jan. 2015 17:51    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Bruce321 10 Unities + Antwort hilfreich
What kind of loads have you got on your model?
Please run a first analysis with nlgeom,off for sanity check.
Gruß, A.
Bruce321
erstellt am: 08. Jan. 2015 21:00    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I do get the solution now after applying displacement of 1% and 10% in X direction (1mm/10mm for 100mm model)  . It was stupid on my part to overlook the boundary conditions
I want it to displace it by 50% (50mm) but unfortunately I am getting an unconverged solution after time of (0.55s)
The number of substeps for the above variation I used were
NSUBST,250,1000,50.
Can you suggest me how to get a converged solution for the same.
Regards,
Bruce
arnd13
Dipl. Ing.
erstellt am: 09. Jan. 2015 09:58    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Bruce321 10 Unities + Antwort hilfreich
Hi Bruce,
I never analysed a model with such very high deformation. I reckon that the distorsion of the elements is getting quite big, maybe out of the limits. I can imagine that it is possible to re-mesh during calculation, but I can't help you sorting this out.
You should check why you do not get a converged solution on file.err. You can always try increasing the number of substeps significantly. This usually promotes convergency.
Gruß, A.
Bruce321
erstellt am: 17. Jan. 2015 12:49    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I get the solution but I get several “ ...u-p elements do not satisfy the volumetric compatibility" output messages during solution. Can anyone tell me how to improve this and how much impact it has on accuracy of a problem.
Thanks,
Bruce
