Hallo Leute,
mein Rechnung konvergiert nicht und da bekomme ich folgende Warn- bzw Fehlermeldungen:
*** WARNING *** SUPPRESSED MESSAGE CP = 6905.359 TIME= 16:02:07
There are 2909 small equation solver pivot terms.
*** ERROR *** SUPPRESSED MESSAGE CP = 6905.375 TIME= 16:02:07
The value of UZ at node 13 is 1169880.54. It is greater than the
current limit of 1000000. This generally indicates rigid body motion
as a result of an unconstrained model. Verify that your model is
properly constrained.
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
If one or more parts of the model are held together only by contact
verify that the contact surfaces are closed. You can check contact
status in the SOLUTION module for the converged solutions using
CNCHECK.
Rigid body motion can also occur when net section yielding has
occurred resulting in large displacements for small increments of load
or when buckling has occurred. You can plot the time history curve
for node 13 in the UZ direction to check for stiffness (slope of the
curve) approaching zero.
*** WARNING *** SUPPRESSED MESSAGE CP = 6912.250 TIME= 16:02:14
There are 1 small equation solver pivot terms.
*** WARNING *** SUPPRESSED MESSAGE CP = 6915.547 TIME= 16:02:18
*** WARNING *** SUPPRESSED MESSAGE CP = 6920.812 TIME= 16:02:24
*** WARNING *** SUPPRESSED MESSAGE CP = 6924.750 TIME= 16:02:29
*** WARNING *** SUPPRESSED MESSAGE CP = 6926.219 TIME= 16:02:30
The calculated reference MOMENT CONVERGENCE VALUE = 3.028790325E-04 is
less than 1E-2 a threshold zero, A value of 1E-2 or specified MINREF
is used. Check results carefully.
die mit den pivot items verstehe ich und auch das rigid body problem ist mit irgendwie bewusst, weil mein problem wird quasi nur von kontakt gehalten... aber die letzte meldung ist mir neu und ich würde geren wissen was sie bedeutet und was ich dagegen machen kann...
ich habe ein orthotropes material mit den werten Ex=136N/mm^2 Ey=1N/mm2 und Ez=1N/mm^2 und mein G ist einheitlich 30.000N/mm^2 (weil ich erkannt habe, dass es dadurch wohl besser konvergiert)aber verbessert mich bitte wenn ich falsche annahmen habe!
