Code:
Code_Saturne is running
Working directory (to be periodically cleaned) :
/home/petzold/tmp_Saturne/BODENABSAUGUNG3.CASE1.07011508 Kernel version: /opt/saturne-2.0.2/cs-2.0
Preprocessor: /opt/saturne-2.0.2/cs-2.0/bin
Preparing calculation
Starting calculation
Warning: /opt/saturne-2.0.2/cs-2.0/bin/cs_partition not found.
The partitioner may not have been installed
(this is the case if neither METIS nor.
SCOTCH are avaialable).
Unoptimized partitioning will be used, so
parallel performance may be degraded.
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 1 with PID 2217 on
node petzold-desktop exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
Error running the calculation.
Check Kernel log (listing) and error* files for details
Error in calculation stage.
