Code:
(defun c:UnDynamic ( /
_get_item
_right
_make_key
_dynamic->static_block
_get_locked
_get_dynamic_inserts
_main
(defun _get_item ( collection key / item )
(vl-catch-all-apply
'(lambda ( ) (setq item (vla-item collection key)))
item
(defun _right ( str n / len )
(if (< n (setq len (strlen str)))
(substr str (1+ (- len n)))
str
(defun _make_key ( collection prefix len / key )
( (lambda ( i pad )
(while
(_get_item collection
(setq key
(strcat prefix
(_right
(strcat pad (itoa (setq i (1+ i))))
len
key
0
( (lambda ( pad )
(while (< (strlen pad) len)
(setq pad (strcat "0" pad))
pad
(defun _dynamic->static_block ( blocks insert len )
(vla-ConvertToStaticBlock
insert
(_make_key blocks "STATIC_" len)
(defun _get_locked ( layers / locked )
(vlax-for layer layers
(if (eq :vlax-true (vla-get-lock layer))
(setq locked (cons layer locked))
locked
(defun _get_dynamic_inserts ( blocks / inserts )
(vlax-for block blocks
(vlax-for object block
(if (eq "AcDbBlockReference" (vla-get-objectname object))
(if (eq :vlax-true (vla-get-isdynamicblock object))
(setq inserts (cons object inserts))
inserts
(defun _main ( document / blocks inserts locked len )
(if
(setq inserts
(_get_dynamic_inserts
(setq blocks (vla-get-blocks document))
(progn
(foreach layer (setq locked (_get_locked (vla-get-layers document)))
(vla-put-lock layer :vlax-false)
(setq len (strlen (itoa (length inserts))))
(foreach insert inserts
(_dynamic->static_block blocks insert len)
(foreach layer locked
(vla-put-lock layer :vlax-true)
(princ)
(_main (vla-get-activedocument (vlax-get-acad-object)))
