Hallo Angelika!
Danke für Schnelle Antwort also, als Hauptuser haben alle Vollzugriff und Lesen Ich Habe eigentlich in Regedit alle Rechte So geändert dass alle Vollzugriff und Lesen Rechte haben (Empfehlung von Autodesk).
Hier Autodesk Empfehlung:
Portions of the Windows registry are set as read only for the users group.
To allow members of the users group to run AutoCAD, permissions must be
changed on some of the registry keys.
WARNING: Backup the system and the registry before making any of these
changes.
Use the following procedure to change the registry permissions:
1. Log on as a member of the local administrators group.
2. Start REGEDT32.EXE by going to Start | Run, type regedt32 and press the enter key
3. The Registry Editor is now running.
4. Click in the HKEY_CLASSES_ROOT window to make it active.
5. Click on the HKEY_CLASSES_ROOT key to make it the active key.
6. Click on the Security pulldown.
7. Click on Permissions
8. Click the Advanced button.
9. Click on the Users group for the local machine to highlight it.
10. Click the View/Edit button.
11. The Permissions Entry for HKEY_CLASSES_ROOT is now displayed.
12. Under the Allow section, check all boxes except Write DAC and Write Owner.
13. Click the OK button three times to return to the base Registry Editor window. This may take a few minutes while the registry permissions areupdated.
14. Click on the HKEY_LOCAL_MACHINE window to make it active.
15. Double-click Software to expand it.
16. Click on Autodesk to make it the active key.
17. Click on the Security pulldown.
18. Click on Permissions
19. Click the Advanced button.
20. Click on the Users group for the local machine to highlight it.
21. Click the View/Edit button.
22. The Permissions Entry for Autodesk is now displayed.
23. Under the Allow section, check all boxes except Write DAC and Write Owner.
24. Click the OK button three times to return to the base Registry Editor window. This may take a few minutes while the registry permissions are updated.
25. Log in with an account that is a member of the users group and test
that AutoCAD can now be run.
Aber leider kein Erfolg.
Danke Farid
