Loading Inventor® Import Plug-in for 3D Studio MAX® and 3D Studio VIZ®
Published date: 2007-Feb-21
ID: TS1065394 Applies to:
Autodesk Inventor® Professional 11
Autodesk Inventor® Series 11
Autodesk® 3ds Max® 8
Autodesk® 3ds Max® 7.5
3ds max® 6
Autodesk® VIZ 2007
Autodesk® VIZ 2006
Autodesk® VIZ 2005
Issue
You want to load the Inventor® Import Plug-in for 3D Studio MAX® and VIZ®, as you could in Inventor 10 and previous releases.
Solution
It is still possible to load this plug-in. For detailed instructions of how to load the plug-in, refer to the Readme.htm file located in the Bin folder of the Inventor® installation path.
After following these instructions, the plug-in will be loaded every time that you start 3D Studio MAX® or 3D Studio VIZ®, and there will be three additional file format options available in the Import dialog box: IPT, IAM, and IPN.
As an alternative to loading the plug-in, you can run the LoadInventorImporter.ms file to import an Inventor file. Using this method, 3D Studio MAX and 3D Studio VIZ will start more quickly and use less memory, as the plug-in is only loaded when required.
Note: To use the Inventor Import Plug-in, both Inventor and 3D Studio MAX or 3D Studio VIZ must be installed on the computer.
Give us your feedback on this document:
Resolved my issue.
Helpful but incomplete.
Difficult to find.
Difficult to understand.
Did not resolve my issue.
Document contains broken links and references.
No comment.
Additional feedback:
AUTODESK DOES NOT GUARANTEE THAT YOU WILL BE ABLE TO SUCCESSFULLY DOWNLOAD OR IMPLEMENT ANY SERVICE PACK OR WORKAROUND, OR ANY OF THE TIPS, TRICKS, EXAMPLES OR SUGGESTIONS OUTLINED IN ANY AUTODESK PRODUCT SUPPORT TECHNICAL DOCUMENTS. TECHNICAL DOCUMENTS, SERVICE PACKS AND WORKAROUNDS ARE SUBJECT TO CHANGE WITHOUT NOTICE TO YOU. AUTODESK PROVIDES TECHNICAL DOCUMENTS, SERVICE PACKS AND WORKAROUNDS "AS IS" WITHOUT WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL AUTODESK OR ITS SUPPLIERS BE LIABLE FOR ANY DAMAGES WHATSOEVER INCLUDING DIRECT, INDIRECT, INCIDENTAL, CONSEQUENTIAL, LOSS OF DATA, OR LOSS OF BUSINESS PROFITS OR SPECIAL DAMAGES, THAT MAY OCCUR AS A RESULT OF IMPLEMENTING ANY SERVICE PACK OR WORKAROUND, OR ANY SUGGESTION OUTLINED IN ANY AUTODESK PRODUCT SUPPORT TECHNICAL DOCUMENT, EVEN IF AUTODESK OR ITS SUPPLIERS HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
