Das sagt Adesk dazu:
Side by side installation of Inventor 10 and Inventor 11
Issue:
You want to know if it is possible to install Inventor 11 next to an installation of Inventor 10 on the same machine.
Solution:
There can be only one Autodesk Data Management Server on any machine. Therefore, when ADMS (AUTODESKVAULT) is already installed, Inventor 10 and 11 both need to install the Content Center Libraries into Data Management Server and the AutodeskVault instance. You will not be able to install MSDE (AutodeskVault) instance for both Inventor 10 and Inventor 11 on the same machine.
If that is something you need to do, then you could use with VMWare or use other machines - one as the Content Center/ADMS for R10 and the other as the Content Center/ADMS for R11 as shared Content Center servers.
For more information about various methods of installation of Inventor 11 next to an installation of Inventor 10, please see TS1056549, which will be published soon.
Tobi
