 | Jetzt verfügbar: NVIDIA RTX PRO 6000 Blackwell Server Edition, eine Pressemitteilung
Thema: Geforce4 -> Quadro4 mit Softquadro (1643 mal gelesen)
NobbiB Mitglied
 Beiträge: 579 Registriert: 05.12.2001 MS Windows XP Pro SP2 P4 3,4 GHz, 2GB RAM, Nvidia Quadro4 XGL900
erstellt am: 18. Nov. 2002 10:32 <-- editieren / zitieren --> Unities abgeben:
Für alle CAD-User die mit einer "Spielegrafikkarte bestraft" sind: Now you can finally hack your GeForce into a beautiful cad card: Quadro 4 !!!! Copied from : http://www.guru3d.com/rivatuner/ : Yes it's finally here. You can force the professional Quadro4 family on your normal GeForce4 without soldering on the PCB to force the Device_ID, all that with a little software patch and a little help from some anonymous friends that is. The ingredients: you'll need this patch-script and the latest version of RivaTuner, any of the Detonator drivers 27.xx – 41.03 and a Graphics adapter GeForce4 Ti4x00 based on NV25 GPU. What you need to do is this: Unpack SoftQuadro4 Script Pack in the same folder, where RivaTuner is Unpack Detonator driver distributive package in separate folder. Make preparations to manually install unpacked driver. This step is necessary only when you are using Detonator 30.82 or higher under Windows 2000/XP. Starting from this version, nVidia compresses every file from the driver package, what makes impossible manual driver installation by using *.inf data. To prepare driver to the installation procedure which uses info file, copy UnpackDriver.bat file from SoftQuadro4 Script Pack in the driver folder and start it, or just execute the following commands, when you are in the driver folder: expand -r *.??_ ren *.cf *.cfg ren *.cp *.cpl ren *.dl *.dll ren *.ex *.exe ren *.hl *.hlp ren *.sy *.sys ren *.tv *.tvp Start NVStrap antiprotection script from RivaTuner package (NVStrap antiprotection w9x.rts file for Windows 9x/ME or NVStrap antiprotection w2k.rts for Windows 2000/XP). You can do this by clicking needed file icon in Windows Explorer (scripts located in PatchScriptsNVIDIANVStrap subfolder of RivaTuner’s folder) or by pressing Open patch script button under PowerUser tab of RivaTuner. After you’ve started the script, press the Continue button and browse for location of the folder, where unpacked driver is. Application will automatically open and patch the needed file. Start SoftQuadro4 script intended for your OS (it is located in PatchScriptsNVIDIASoftQuadro4 subfolder of RivaTuner's folder) and repeat previous step. Install NVStrap driver from RivaTuner package and activate its PCI DeviceID reprogramming function. To do this under Windows 9x you will need to include NVStrap.com DOS driver file (it is located in ToolsNVStrap subfolder of RivaTuner’s folder) in the autoexec.bat file like this: C:RivaTunerToolsNVStrapNVStrap.com G+ If you are using Windows 2000/XP you can install and configure NVStrap through the driver configuration panel of RivaTuner. Gruß NobbiB
Charly Setter Moderator
 Beiträge: 11981 Registriert: 28.05.2002 Der vernünftige Mensch paßt sich der Welt an; der unvernünftige besteht auf dem Versuch, die Welt sich anzupassen.<P>Deshalb hängt aller Fortschritt vom unvernünftigen Menschen ab. (George Bernard Shaw)
erstellt am: 18. Nov. 2002 18:47 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Unter der gleichen URL gibt´s auch den 40.71-Treiber gepatcht für Quattro 4 GO Chipsätze. Für Alle, die von Ihrem Notebookhersteller nicht mit den neuen Triebern ausgestattet werden :-). Gruß Mathias Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 18. Nov. 2002 19:34 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Hans L Mitglied Maschinenbautechniker
 Beiträge: 131 Registriert: 07.01.2002 AIS + Subscription, 2x P4 / 2,8 GHz 1 GB DDR Ram Quadro 4 XGL 580 Spacemouse Plus XT
erstellt am: 19. Nov. 2002 07:21 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Grüß Euch, ...hört sich ja super an. Funktioniert das auch mit einer GF 4 MX 440 von Aopen und was genau brauch ich jetzt alles (mein Englisch läßt zu wünschen übrig :-) ? Hans ------------------ Grüße Hans Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
skidiver Mitglied
 Beiträge: 35 Registriert: 20.09.2002
erstellt am: 19. Nov. 2002 10:20 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Billa Mitglied CAD-Konstrukteur
 Beiträge: 61 Registriert: 06.09.2002
erstellt am: 19. Nov. 2002 10:35 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Es geht glaube ich primär um die erweiterten OpenGL Eigenschaften, die diese Quatro hat. Diese Grafikchips setzten natürlich auch schnelle Prozessoren voraus. Falls ich mich da täusche bitte um Berichtigung. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
brainseks Ehrenmitglied V.I.P. h.c. Konstrukteur / Entwicklung
 Beiträge: 3181 Registriert: 26.07.2002 Intel Core i5-3570K, Asus P8Z77-V Pro, Intel 320 SSD 128GB System, WD-5000AAKS Daten, Geforce GTX460 1GB, Windoof 7 home Premium 64bit (privat)<P>Samsung R540 i3-380M JA05 /Intel Core i3-380M 2x 2,53GHz / Intel X25-M G2 80GB System, 4096MB DDR3 Ram / Intel® HD Graphics / Webcam u. int. Mikro, DVD Brenner / Windows 7 Home Premium 64 Bit (Notebook privat)
erstellt am: 19. Nov. 2002 11:04 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Also hoi mal Meinen Erfahrungen nach ( ich hab den Umbastelbau eine Geforce zu Quadro mal mit Geforce 2 gemacht) geht es bei dem Softquadro bzw. Geforce-Quadro darum, den Quadro Treiber benutzen zu können. Fakt ist, dass alle Geforce Chips eigentlich Quadro Chips sind, bzw. umgekehrt. Vermutlich um Produktionskosten zu sparen. Der Quadrotreiber bietet eine kleine Anzahl von erweiterten OpenGL Funktionen und soll damit eine Bessere Unterstützung der in CAD Progs vorkommenden Aktionen bieten. Ein Stabilitätszuwachs sollte auch merkbar sein. Ich habe mal eine Geforce Karte mit Einsatz von Lötkolben und Widerständen un son Zeug gemacht, um die Quadro freizuschalten. Genauso hab ich den Softquadro mal benutzt und getestet. Die angebliche Performancesteigerung konnte ich nur in einem kleinen Rahmen mit Benchmarktools erfassen. Stabilitätszuwachs kann ich nicht leugnen aber auch nicht bestätigen. Also meiner Meinung nach kann man das machen, man kanns auch lassen, denn bringen tuts merklich nix. Aber immer noch besser als sich eine völlig überteuerte Quadrokarte zu kaufen ist es allemal. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Pisarz Mitglied
 Beiträge: 280 Registriert: 05.03.2002 AIP2011 Win7x64 HP Z400/W3565(3.2GHz) 12GB RAM 100GB SSD / 1TB Raid1 MSI R5770 Hawk SpacePilot
erstellt am: 19. Nov. 2002 13:26 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Zitat: Original erstellt von brainseks: Fakt ist, dass alle Geforce Chips eigentlich Quadro Chips sind, bzw. umgekehrt.
Das stimmt meines Wissens nicht ganz, es gibt schon Unterschiede zwischen den Chips, nicht jedoch in deren Ansteuerung und grundsätzlichem Aufbau, d.h. das gesamte Kartendesign ist bei Geforce und Qaudro gleich. Die Freischaltungen (ich hab auch mal 'ne Geforce2 zu einer Quadro2 umgelötet) betreffen das Karten-BIOS und hier werden Teile der "Quadro-Software" tatsächlich freigeschaltet und der Detonator-Treiber erkennt eine Quadro und arbeitet deswegen vermutlich auch etwas schneller. Den Chip-Unterschied merkt man dann aber, wenn man das Antialasing von Linien-Grafiken einschaltet. Hier kann kein Geforce-Chip mithalten. Diese Hardware scheint wirklich nur auf den QuadroChips vorhanden zu sein. Anyway, der psychologische Effekt von Softquadro ist nicht zu leugnen. Und schließlich kommt es ja auf den "gefühlten" Geschwindigkeitszuwachs an  @Hans: Aber eine GF4 MX bringt das nicht wirklich weiter. Wenn schon sparen, dann versuche wenigstens eine GF4 TI 4200 / 128MB einzubauen. Der Unterschied zwischen MX und TI ist erheblich. ------------------ Grüße Jörgen Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
skidiver Mitglied
erstellt am: 21. Nov. 2002 10:19 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Nun doch sind Änderungen sichtbar: ich hab unter Anwendungsoptionen/Hardware mal die Einstellung verändert und dann wieder zurückgestellt. Das hat IV anscheinend veranlasst die Quadro erstmal für voll zu nehmen. Nun ist die Darstellung irgendwie ausgeglichener und Rundungen werden sehr viel seltener auf weniger Poligone reduziert. Die OpenGL-Features unter Analyse sind allerdings unverändert. ski Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
berni91 Mitglied Konstrukteur, Sondermaschinenbau
 Beiträge: 48 Registriert: 04.07.2002 IV8SP1, Core2Duo, 4GB RAM, QuadroFX3500
erstellt am: 21. Nov. 2002 10:34 <-- editieren / zitieren --> Unities abgeben:          Nur für NobbiB
Hallo zusammen, ich glaube nicht, dass man mit Softquadro die Geschwindigkeit der Grafikdarstellung wesentlich verbessern kann. Ich habe das vor einiger Zeit mit einer Geforce 2 GraKa probiert und eigentlich keinen Unterschied festgestellt. Man müsste jedoch einen Unterschied bemerken, wenn viele Grafikfenster geöffnet sind. Und wenn nicht, bleibt, wie gesagt, der psychologische Faktor. Viele Grüsse Ralph
