  BricsCAD
  new: CALSCRIPT - scripting tool and GeomCAL replacement
Gut zu wissen: Hilfreiche Tipps und Tricks aus der Praxis prägnant, und auf den Punkt gebracht für BricsCAD
BricsCAD-Lizenzen bis Ende September mit 20 % Rabatt, eine Pressemitteilung
Autor Thema:  new: CALSCRIPT - scripting tool and GeomCAL replacement (313 / mal gelesen)
archtools
Sehen Sie sich das Profil von archtools an!   Senden Sie eine Private Message an archtools  Schreiben Sie einen Gästebucheintrag für archtools
Entwickler für AutoCAD, BricsCAD u.a., alle Systeme
erstellt am: 14. Mrz. 2022 13:25    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hello,
a new powerful tool ist available which brings AutoCAD's GeomCAL functionality to BricsCAD and  adds a powerful scripting tool. Download archtools.de/calscript.zip to get a free copy.
CALSCRIPT can execute any traditional script, and adds parametric design thru scripts. Indeed only three simple declarations in a traditional script make the drawing from the script partametrically editable. Even user input is possible in a running script. And for programmers: a script can be translated to a Lisp function which can be used in any other Lisp application.
Drawings which are created by a CALSCRIPT script can be given away and the receiver can edit the parameters even when he does not have the original script.
CALSCRIPT is still in beta version, more functionality will be added, ie. a batch script tool to run any number of scripts over many dwg files.
CALSCRIPT will be available as a free license, a personal license and a source code license. The only restriction of the free license is that it expires at the end of each year and need to be renewed. The personal license is available at little cost only on a per seat basis and never expires. The source code license allows you to use CALSCRIPT on all your computers in your company, and to distribute CALSCRIPT as a part of your compiled Lisp applications.
No special installation ist necessary. Just load CALSCRIPT.des into BricsCAD. For a quick start just open the sample dwg files and load the script files with the BricsCAD SCRIPT command.
