  NX Programmierung
  Script to modify all NX files in a folder one by one
Teamcenter Herbsttagung | 28. Oktober 2026 | Siemens AG, Erlangen Termin: in 5 Wochen
Solid Edge 2023 Upgradekurs , ein Kurs
Autor Thema:  Script to modify all NX files in a folder one by one (4012 mal gelesen)
Lenno
Naval Architect
Sehen Sie sich das Profil von Lenno an!   Senden Sie eine Private Message an Lenno  Schreiben Sie einen Gästebucheintrag für Lenno
Rhino 4.0
Autocad Mechanical 2007
Unigraphics NX5
NAPA<P>HP xw6400 workstation
Intel Xeon
5120 @ 2 GHZ
4 Gig Ram
erstellt am: 27. Mai. 2009 11:44    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
I have to change the color of a large number of JT files in a folder. I recorded a journal in NX5 to change the color, but I can't find a way to let NX open all files in the folder one by one.  Now it only opens Part1, but I like to create some kind of a batch proces.
Any ideas? Replies in German are fine.
Thanks...
' NX 5.0.4.1
' Journal created by llu on Wed May 27 11:11:17 2009 W. Europe Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
'  Menu: File->Open...
Dim basePart1 As BasePart
Dim partLoadStatus1 As PartLoadStatus
basePart1 = theSession.Parts.OpenBaseDisplay("C:\Documents and Settings\llu\Desktop\FOLDER1\FILE1.jt", partLoadStatus1)
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
partLoadStatus1.Dispose()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Enter Gateway")
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Open Part Navigator")
Dim markId3 As Session.UndoMarkId
markId3 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Enter Gateway")
'  Menu: View->Operation->Fit
workPart.ModelingViews.WorkView.Fit()
'  Menu: Edit->Object Display...
Dim markId4 As Session.UndoMarkId
markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
theSession.SetUndoMarkName(markId4, "Class Selection")
' Refer to the sample NXOpen application, Selection for "Select All" alternatives.
Dim markId5 As Session.UndoMarkId
markId5 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Class Selection")
theSession.DeleteUndoMark(markId5, Nothing)
theSession.DeleteUndoMark(markId4, Nothing)
'  Dialog Begin Edit Object Display
Dim markId6 As Session.UndoMarkId
markId6 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Object Display")
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
displayModification1.ApplyToAllFaces = False
displayModification1.NewColor = 128
Dim objects1(0) As DisplayableObject
Dim facetedBody1 As Facet.FacetedBody = CType(workPart.FacetedBodies.FindObject("HANDLE R-96"), Facet.FacetedBody)
objects1(0) = facetedBody1
displayModification1.Apply(objects1)
displayModification1.Dispose()
'  Menu: File->Save
Dim partSaveStatus1 As PartSaveStatus
partSaveStatus1 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partSaveStatus1.Dispose()
Dim partCloseResponses1 As PartCloseResponses
partCloseResponses1 = theSession.Parts.NewPartCloseResponses()
workPart.Close(BasePart.CloseWholeTree.False, BasePart.CloseModified.UseResponses, partCloseResponses1)
workPart = Nothing
displayPart = Nothing
partCloseResponses1.Dispose()
'  Menu: Tools->Journal->Stop
End Sub
End Module
mseufert
Freiberuflicher CAD/CAM Ingenieur
Sehen Sie sich das Profil von mseufert an!   Senden Sie eine Private Message an mseufert  Schreiben Sie einen Gästebucheintrag für mseufert
HP Z420
WIN7 64 Win 10
UG NX6-2306
3D Printer Prusa MK2 S
erstellt am: 27. Mai. 2009 12:40    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Lenno 10 Unities + Antwort hilfreich
batch_cleanup.txt
Hi Lenno,
appended you can find a sample to process all parts in a directory. With that, there are two further steps to perform: First, replace the actions that are done for each part with your own ones. Second, for modifying the display of an Object you'll need an ID of it - or any other way to find out, which object's display should be changed. May be for all faceted bodies in the part?
Michael
Lenno
Naval Architect
Rhino 4.0
Unigraphics NX5
Intel Xeon
5120 @ 2 GHZ
4 Gig Ram
erstellt am: 28. Mai. 2009 09:00    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Thanks a lot mseufert, I'm gonna try it!
Lenno
Naval Architect
Rhino 4.0
Unigraphics NX5
Intel Xeon
5120 @ 2 GHZ
4 Gig Ram
erstellt am: 28. Mai. 2009 09:57    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hmm..
I modified the code, but there is problem with the difinition of the facetedbody1
' NX 5.0.4.1
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
For Each fileName As String In My.Computer.FileSystem.GetFiles(C:\Documents and Settings\llu\Desktop\BLK10\BLK10)
basePart1 = theSession.Parts.OpenBaseDisplay(fileName, partLoadStatus1)
'  Menu: File->Save
workPart = Nothing
Next
End Sub
End Module
Lenno
Naval Architect
Rhino 4.0
Unigraphics NX5
Intel Xeon
5120 @ 2 GHZ
4 Gig Ram
erstellt am: 28. Mai. 2009 10:31    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Its working... !!
Thanx
' NX 5.0.6.3
' Journal created by cwei on Thu May 28 10:21:44 2009 Westeuropäische Normalzeit
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
For Each fileName As String In My.Computer.FileSystem.GetFiles("Y:\NX\Makro Change Color\JTs")
displayModification1.NewColor = 150
'  Menu: File->Save
workPart = Nothing
Next
End Sub
Ausbildungsmeister (w/m/d) Metalltechnik mit Schwerpunkt Land- und Baumaschinenmechatronik
Die Handwerkskammer Dresden ist als Körperschaft des öffentlichen Rechts die Selbstverwaltung und Interessenvertretung von rund 21.000 Handwerksbetrieben mit etwa 120.000 Beschäftigten im Kammerbezirk Dresden, zu dem die Landkreise Görlitz, Bautzen, Meißen, Sächsische Schweiz-Osterzgebirge und die Landeshauptstadt Dresden gehören. Zu ihren Aufgaben gehört neben der Interessenvertretung und der Erfüllung hoheitlicher Aufgaben auch die Handwerksförderung im weiteren Sinn....
mseufert
HP Z420
WIN7 64 Win 10
UG NX6-2306
erstellt am: 28. Mai. 2009 19:15    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Lenno 10 Unities + Antwort hilfreich
Hi Lenno,
fine, and also a little surprise. In your code, the entry workPart.FacetedBodies.FindObject("HANDLE R-96") looks for an object called "HANDLE R-96". This must be the same in all of the parts for the program to work. Seems you're a lucky man.
Regards, Michael
