Aus der Online Hilfe:
Graphs are created based on the result shown in the current post view. Before creating a graph, set up a post view showing the result or result component you want to graph.
Create a graph along a path
1.In the Post-Processing Navigator, right-click a post view and choose Create Graph.
2.From the Graph Type list, select Extract On Path.
3.Name the graph.
4.From the Path list, select an existing path, or click Create to create a new path.
5.Specify settings for Abscissa, NoData, and Value Sharing.
6.Specify how you want the software to interpolate values between nodes or points in your path:
◦Select Include Intersections when you want to create a smooth graph of the changes in data values between nodes or points.
◦Clear the Include Intersections check box when you want to compare discrete values at specified nodes or points.
7.Click OK.
The graph definition is listed under the solution node in the Post-Processing Navigator, and the graph is saved as an AFU file. If you select Plot graph on creation, the graph is plotted in the current or selected viewport.
MfG Alexander
