Die Logfile sieht folgendermassen aus:
43 (lmgrd) Can't make directory C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\Macrovision, errno: 17(File exists)
15:44:43 (lmgrd) Done rereading
15:44:43 (lmgrd) FLEXlm (v8.3b) started on thom (IBM PC) (6/29/2004)
15:44:43 (lmgrd) FLEXlm Copyright 1988-2002, Macrovision Corporation
15:44:43 (lmgrd) US Patents 5,390,297 and 5,671,412.
15:44:43 (lmgrd) World Wide Web: http://www.globetrotter.com
15:44:43 (lmgrd) License file(s): C:\Programme\EDS\License Servers\UGNXFLEXlm\ugnx2.lic
15:44:43 (lmgrd) lmgrd tcp-port 27000
15:44:43 (lmgrd) Starting vendor daemons ...
15:44:43 (lmgrd) Started uglmd (pid 456)
15:44:43 (uglmd) Invalid license key (inconsistent authentication code)
15:44:43 (uglmd) ==>FEATURE server_id uglmd 20.0 permanent 1 F0A4C5BC0A8A \
use [...]
15:44:43 (uglmd) Server started on thom for:
15:44:43 (uglmd) ACD (consisting of: ACD_3d_to_2d_flattener
15:44:43 (uglmd) ACD_adv_assemblies ACD_adv_sheet_metal_dsgn ACD_ansys_meshers
15:44:43 (uglmd) ACD_assemblies ACD_cam_base ACD_cam_dialogs
15:44:43 (uglmd) ACD_cavity_milling ACD_design_studio ACD_die_engineering
15:44:43 (uglmd) ACD_drafting ACD_dxf_to_ug ACD_dxfdwg
15:44:43 (uglmd) ACD_features_modeling ACD_fix_axis_surf_mill ACD_flat_patterns
15:44:43 (uglmd) ACD_flow_cut ACD_free_form_modeling ACD_gateway
15:44:43 (uglmd) ACD_geometric_tol ACD_gfem_ansys ACD_gfem_nastran
15:44:43 (uglmd) ACD_graphical_tool_path ACD_grip_execute ACD_iges
15:44:43 (uglmd) ACD_mechanisms ACD_motion_dyn ACD_motion_kin
15:44:43 (uglmd) ACD_nurb_output_enabler ACD_planar_milling ACD_prog_die_wizard
15:44:43 (uglmd) ACD_pv_ugdatagenerator ACD_routing_base ACD_routing_combined
15:44:43 (uglmd) ACD_routing_conduit ACD_routing_piping ACD_routing_raceway
15:44:43 (uglmd) ACD_routing_steelwork ACD_routing_tubing ACD_routing_wiring
15:44:43 (uglmd) ACD_sequential_milling ACD_sheet_metal ACD_sheet_metal_design
15:44:43 (uglmd) ACD_shop_doc ACD_sla_3d_systems ACD_solid_modeling
15:44:43 (uglmd) ACD_std_ug_library ACD_step_ap203 ACD_step_ap214
15:44:43 (uglmd) ACD_studio_analyze ACD_studio_free_form ACD_studio_render
15:44:43 (uglmd) ACD_studio_visualize ACD_surface_milling ACD_tol_cavity_milling
15:44:43 (uglmd) ACD_ufunc_execute ACD_ug_collaborate ACD_ug_epak
15:44:43 (uglmd) ACD_ug_isv_full ACD_ug_kf_author ACD_ug_kf_execute
15:44:43 (uglmd) ACD_ug_mold_design ACD_ug_opt_wizard ACD_ug_post_exe
15:44:43 (uglmd) ACD_ug_post_mill ACD_ug_scenario ACD_ug_schematics
15:44:43 (uglmd) ACD_ug_smart_models ACD_ug_strength_wizard ACD_ug_struct_pe_solver
15:44:43 (uglmd) ACD_ug_to_dxf ACD_ug_turning ACD_ug_visualize
15:44:43 (uglmd) ACD_ug_vki_meshers ACD_ugopen_menuscript ACD_ugopen_plus_plus
15:44:43 (uglmd) ACD_ugweld ACD_ui_styler ACD_usr_defined_features
15:44:43 (uglmd) ACD_var_axis_surf_mill ACD_wave ACD_wire_edm_machining)
15:44:43 (uglmd) 3d_to_2d_flattener ansys_meshers cam_facets
15:44:43 (uglmd) gfem_ansys gfem_nastran ug_holemaking
15:44:43 (uglmd) ug_isv_full ug_scenario ug_struct_pe_solver
15:44:43 (uglmd)
15:44:43 (uglmd) Licenses are case sensitive for this vendor
15:44:43 (uglmd)
15:44:43 (lmgrd) uglmd using TCP-port 4448
SUPERÁá
Ich hoffe es hilft weiter.
