! ** File Format Information **
! ** Customer Defaults are described in this file as name:value pairs. **
! ** Each default is defined on one or more lines with a "name : value" **
! ** format. **
! ** The name identifier is of the form 'ApplicationID_DefaultName'. **
! ** If the application id is absent, the default is considered a **
! ** "user-specified" customer default. **
! ** The total length of the name identifier (i.e. application id and **
! ** default name) must not exceed 40 characters. The default name may be **
! ** composed of any combination of upper and lower case alphanumeric **
! ** characters (A-Z, a-z, 0-9), dashes (-) or underscores (_). No other **
! ** characters or embedded white space is allowed in the name identifier. **
! ** The value identifier may be composed of a maximum of 800 characters **
! ** and may span any number of lines (Note: Any non-terminating line MUST **
! ** END with a backslash (\) character). Leading and trailing whitespace **
! ** is permitted but is removed by the scanner. Embedded whitespace is **
! ** allowed and will be tokenized. The backslash may be used to force the **
! ** scanner to skip the character immediately following it. On Windows NT **
! ** each intended backslash must be preceded by an 'escape' backslash. **
! ** Example: z:\users\foo should be represented as z:\\users\\foo. **
! ** Comments are denoted by the exclamation point (!) and may appear on **
! ** their own line or following a value identifier. **
Habe nur das auf die schnelle gefunden, aber es gibt noch eine Variable die erlaubt sowohl grosse als auch kleine Buchstaben...
Konrad Wieclawski
