Patch C behebt folgende Probleme...
? PR1197272 - UGManager Performance issue (V18.0.5.2)
? PR4575150 - KF (Performance problem under iMAN)
? PR4574441 - IMAN access to Checkmate
? PR4475740 - X-form experiences a Signal 11 Error when editing surface (important to Design Center) (v18.0.5.1)
? PR4353317 - Change component name fails when "Preview Component on Add" is active (V19)
? PR4577757 - UG Manager -- Clone-based import/export (V18.0.5.1)
? PR4574914 - ugpc failing in 18.0.4.2 (V18.0.5.1)
? PR1181529 - Section Line modified after loading drawing in V18 (V18.0.5.1)
? PR1171801 - PSOP: Layer Move fails with Internal Error (V18.0.5.1)
? PR1182093 - Internal error when trying to wave link body (V18.0.5.1)
? PR1183557 - Internal Error during Update Session (V18.0.5.1)
? PR1173977 - Open IR: PSOP: Can open UG part after saving in V18.0.3.3 (NF)
? PR1186650 - CAD: - EDS/Opel-Cannot open part (V18.0.5.1)
? PR4577256 - Ug hangs when opening part file (V18.0.5.1)
? PR1183346 - Cannot open file after save. (V18.0.5.1)
? PR4564143 - A small part causes UG to hang while opening the part (V18.0.5.1)
? PR1178923 - File fails to open. (V18.0.5.1)
? PR1177543 - TDC: OFFSET (24) switches face after update and causes update failure (V18.0.5.1)
? PR4580024 - UG/Manager V18.0.3.3 loads based on Item ID, rather than Item UID****** in order to trigger the behavioral change this fix provides you must set the environment variable UGII_UGMGR_PREFER_UID_ON_RENUM in your environment before running UG/Manager*****
? PR4575702 - Taper using tangent faces does not updated correctly when editing (V18.0.5.1)
? PR1193715 - CAD:-OPEL/TDC: Critical issues with Opel DMU (V18.0.5.2)
? PR1191891 - Internal error while closing assembly (V18.0.5.2)
? PR4582421 - Memory access violation when opening a new part in UG (V18.0.5.2)
? PR4574554 - PSE does not have sequence numbers after clone import of an assembly (V18.0.5.2)
Parasolid fixes generated between v13.2.235 and v13.2.242
? PR4250675 - v18 DENSO: Offset does not merge faces as it previously did
? PR4250685 - Body disappears after offsetting face.
? PR4569855 - Mass Properties reports different results from v15 to v18
? PR4578477 - Mass Properties differences between v15 and v18 with no model change
? PR1171686 - CAD:-PSOP:-EDS/Opel- Thickensheet fails to update with internal error (reassigned to UG) (V18.0.5.1)
? PR4557906 - P4 fails, but P3 Kernel works correctly with large assembly in W2K
and XP-Pro
Gruss, Konrad
