hallo alfred,
folgendes habe ich in den discussion groups zu deiner fehlermeldung gefunden. vielleicht hilft es auch bei dir?
Fatal Error Attempt to delete class 'AecDatabasedata' (2 replies)
Posted by: Mochrie, Craig
Date: Jan/29/03 - 02:39 (GMT)
Running ADT2 on XP pro, Installed it with compatibility with Win2000
If I attempt to load a previously saved drawing with Aec objects it aborts
without warning.
Also if I attempt to initiate a new drawing with the Aec Arch template I get
the following message
Fatal Error: Attempt to delete class 'AecDatabaseData' which still has
registered dependants.
I am at a loss. I have uninstalled and re installed and am having no luck.
BTW If I use a more basic template or start from scratch it works ok until I
use an Aec object, say a wall and then it jumps out without warning. Also I
cannot use my system printer anymore, I get a Memory Allocation Error.
Please assist if you can,
Craig.
Reply From: Catana, Anthony
Date: Feb/07/03 - 06:57 (GMT)
Re: Fatal Error Attempt to delete class 'AecDatabasedata'
I had the same problem.
You need to turn off compatability.
Right click on the AutoCad.exe program and select properties. go to
Compatibility and turn it off.
ADT 2i works fine in XP Pro.
"Craig Mochrie" <cmochrie@bigpond.net.au> wrote in message
news:4E724BEC8BFB5E20D177668AB4B011AE@in.WebX.maYIadrTaRb...
> without warning.
get
luck.
I
I
> Craig.
Reply From: Mochrie, Craig
Date: Feb/09/03 - 22:58 (GMT)
Re:
Anthony, You are a SAINT.
I have been wrestling with this for three weeks, trying to get some answers.
Thank you for a simple and effective fix.
Craig. ;-)
"Anthony Catana" <tonyc@spiezle.com> wrote in message
news:4C141DA0AF76026A9AF049561EB2A7D0@in.WebX.maYIadrTaRb...
aborts
> > without warning.
> get
> luck.
until
> I
Also
> I
> > Craig.
freundliche grüsse
christian schütz
acadgraph support
www.acadgraph.de
