 | E3.view , eine App
Thema: With greetings from Russia. Invite to dialogue! (4441 mal gelesen)
Denis S Mitglied Software integration support
 Beiträge: 16 Registriert: 08.01.2007 Hi! Unfortunately hoster accidentally destroyed sql database on my site ... :( And I did not renew hosting. That script here: http://e3series.ru/SelfFiles/file/script/renamepoz.rar<P>Regards<P>Denis Semenov<P>POINT LTD St. Petersburg, Russia www.pointcad.ru www.e3series.ru
erstellt am: 10. Jan. 2007 10:31 <-- editieren / zitieren --> Unities abgeben:
Hello! We use E3.Series about half a year. Basically small and average automation projects for our oil refinery. On the average 10-20 positions "devices in a field". Each engineer carried out from 2-4 projects in a month. In projects can be as "equipment in a cabinet", and as "devices in a field"("Plans of lines", "Schemes of connection of external lines") as we make the documentation for «systems of management and monitoring» - "Algorithms of the control and management"," Sketches of the frame for operator’s station", "the List of parameters". We do the "Expansions" of existing control systems which have been made by others organizations. Examples of works: "Cabinet for a control system of pumps" http://sdb.name/shkaf.htm “Expansion of the system of management and monitoring" http://sdb.name/shkaf2.htm Here are descriptions of scripts WBS (Windows Based Script) for E3.Series (E3.Caddy) my development: http://sdb.name/#sc ("The table of connections of the panel wiring" (Connections_table_v2.vbs)) Here my clause devoted E3 in December number Russian magazine about CAD: http://www.e3.caddy.ru/doc/06-12.pdf Here a forum about E3 on Russian site: http://www.cad.ru/ru/forum/read.php?FID=21*TID=925 What your impression about work in E3? Questions, problems, wishes? …apologize for my English
erstellt am: 06. Mrz. 2007 07:57 <-- editieren / zitieren --> Unities abgeben:
wrote an interesting script... The description and example of work of the script "Projections for the panel" for the E3.series system (Projection _v2.vbs).
The script creates projections for selected models on the panel. (left-side view/right-side view/bottom view/top view) The example of work for the panel: 1) Selected all objects on the panel: 2) Selected all objects on the panel. Scale factor coefficient - 0,5: 3) Some objects selected on the panel: The script is tuned through the configurations file: Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 02. Mai. 2007 14:44 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 03. Mai. 2007 08:13 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Started to do plans of lines on a "panel drawing". There were some problems: 1. Models cannot be turned on the set degrees (only on 90 degrees) 2. Periodically, communications between boxes have disappeared. 3. Boxes model had to do by meter height that was communication between models on height. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
timmle Mitglied Entwicklungsing.
 Beiträge: 234 Registriert: 17.02.2005
erstellt am: 03. Mai. 2007 10:19 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Hello Denis, 1) which version of E3 uses you? In 2007 you can rotate parts in 0.1 degree steps. 2) what do you mean with "communication between boxes"? 3) I don't understand, what you mean. Please, show the context between question and drawing. ------------------ Gruß Uwe Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 07. Mai. 2007 08:59 <-- editieren / zitieren --> Unities abgeben:
Zitat: which version of E3 uses you?
Build 2006-541 (Sep 14 2006). Zitat: In 2007 you can rotate parts in 0.1 degree steps.
And models for panel too? Zitat: what do you mean with "communication between boxes"?
Between nearby Cable Duct’s there is communication (And it’s have a docking point). I’m open a file of the project … and this communication is not present (and accordingly does not work Panel Autoconnect). Zitat: I don't understand, what you mean.
I am talking about a situation where the model "A" (height = 100mm), located on the model "B" (height = 700mm), and I need to do Panel Autoconnect through Cable Duct, for this I do model Cable Duct height 1000mm:
erstellt am: 07. Mai. 2007 13:15 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
erstellt am: 10. Mai. 2007 08:57 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 29. Mai. 2007 09:14 <-- editieren / zitieren --> Unities abgeben:
The description and example of work of the script "Connections table for panel" for the E3.series system (Connections_table_v2_eng.vbs).
The Script generates “the table of connections and connections” . The table contains all the wires and cables from the panel. The cables are deduced by the last. The script counts up total length of all wires and cables. Thus length of a cable = length of its wire of the maximal length. During work of the script opens window: If to enter number distinct from zero the script will generate an additional column in the table, see 1 · During work of the script also, opens dialogue window:
If to answer "Yes"("Да” , there will be a supplementary the table of necessary characters for mark. See 2 Counting marking specially made optional because if the count is not necessary and press “no”(“Нет” in the dialog windows the script works much faster that essential in major projects (> 100 wires) · During work of the script also, open dialogue window:
If to answer "Yes"("Да” , there will be a supplementary table of the crimp contact. See 3 The quantity of crimp contacts = quantity of wires х 2(supposed, that on a wire crimp contacts on both ends). · The script works with sheets from the database with the names: A4_TC_sh_1- first list A4_TC_sh_2- second and subsequent · The script is tuned through the configurations file(config.txt), which should be in one folder with script: If in a column "To request" to specify "no" the script will work with value "default", without call dialogue window. Example of work: Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jun. 2007 13:50 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
erstellt am: 05. Okt. 2007 08:52 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Zitat: Original erstellt von Denis S: The description and example of work of the script "Connections table for panel" for the E3.series system (Connections_table_v2_eng.vbs).
erstellt am: 05. Okt. 2007 08:59 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
erstellt am: 19. Dez. 2007 08:58 <-- editieren / zitieren --> Unities abgeben:
Rolf K. Ehrenmitglied CAD-Konstrukteur
 Beiträge: 1730 Registriert: 10.12.2002
erstellt am: 29. Dez. 2007 18:41 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
erstellt am: 04. Feb. 2008 13:20 <-- editieren / zitieren --> Unities abgeben:
Chuhran Mitglied
 Beiträge: 3 Registriert: 04.07.2008
erstellt am: 24. Sep. 2008 09:43 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
erstellt am: 08. Okt. 2008 20:35 <-- editieren / zitieren --> Unities abgeben:
erstellt am: 20. Mai. 2009 22:48 <-- editieren / zitieren --> Unities abgeben:
Inviter09 Mitglied tech. Ang.
 Beiträge: 36 Registriert: 04.06.2009
erstellt am: 12. Jun. 2009 22:27 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Hi Was interested in your Group-Rename Skript, which you mentioned in early February. Just to check out, how you do things, and maybe for extending it. But I had to find out, that the download-link is dead. Do you have a new source where i could download the script, because it sounds interesting to me. Really nice work guy, and nice presentation of your work as well. But my russian is weak, and I dont understand much, when I am browsing through you website. Greets Inviter09 Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 03. Nov. 2009 12:46 <-- editieren / zitieren --> Unities abgeben:
Zitat: Original erstellt von Inviter09: HiWas interested in your Group-Rename Skript, which you mentioned in early February. Just to check out, how you do things, and maybe for extending it. But I had to find out, that the download-link is dead. Do you have a new source where i could download the script, because it sounds interesting to me. Really nice work guy, and nice presentation of your work as well. But my russian is weak, and I dont understand much, when I am browsing through you website. Greets Inviter09
Hi! Unfortunately hoster accidentally destroyed sql database on my site ... And I did not renew hosting. That script here: http://e3series.ru/SelfFiles/file/script/renamepoz.rar Regards Denis Semenov POINT LTD St. Petersburg, Russia www.e3series.ru
[Diese Nachricht wurde von Denis S am 03. Nov. 2009 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 03. Nov. 2009 18:14 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Zitat: Original erstellt von Inviter09: ... But my russian is weak, and I dont understand much, when I am browsing through you website...
Hallo Inviter09, You can feed for example the URL of a russian site into the input field of the search engine Google. Google will offer You to translate this site into Your language. I think this will help a little. ------------------ Es grüsst Rolf K. [Diese Nachricht wurde von Rolf K. am 03. Nov. 2009 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
 Beiträge: 36 Registriert: 04.06.2009 2024
erstellt am: 14. Nov. 2009 12:05 <-- editieren / zitieren --> Unities abgeben:          Nur für Denis S
Thank you very much for the download link. I promise to send you a notification and a copy of everything when I added my features to yours. Quite a lot work in the moment, so I think it will be around christmas. Thank you again. Inviter09 ---------- спасибо большое за ссилку. я обязательно напишу тебе, когда все будет готово, и вишлю копию всего, после того, как я добавлю новие функции к твоим. сейчас много работи, но думаю, что до Рождества все будет готово. еще раз большое спасибо. Inviter09
erstellt am: 01. Mrz. 2011 08:01 <-- editieren / zitieren --> Unities abgeben:
