  PTC Creo Elements/Direct Modeling
  Problems of custom feature holes
Autor Thema:  Problems of custom feature holes (636 / mal gelesen)
renchaoroy
Engineer
Sehen Sie sich das Profil von renchaoroy an!   Senden Sie eine Private Message an renchaoroy  Schreiben Sie einen Gästebucheintrag für renchaoroy
DELL-Precision 3530/Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz 2.59
GHZ/16.0 GB/Windows 10 Home/20H2/OS revision19042.985/DirectModeling (x64edition)/Revision: 19.0/Datecode: F000(19.0.0.790,09-May-2014)
erstellt am: 14. Jul. 2021 08:47    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi My Friends,
  I want to define a command for making holes quickly, here is my code, SFace is the selected face, RePnt is the selected 3D point, They are correct.but I am running, the system prompt "parameter not fully defined", is a custom feature does not support Lisp?
Code:
(defun psd-make-hole(SFace YFace SNum)
(let (AllFace RePnt
(OwnerPart (sd-inq-parent-obj SFace))
(SFCenter (sd-vec-scale (sd-vec-add(sd-face-ll-pnt (sd-inq-face-geo SFace :Dest-space :global))(sd-face-ur-pnt (sd-inq-face-geo SFace :Dest-space :global))) 0.5)))
(setf AllFace (sd-call-cmds (get_selection :focus_type *sd-plane-seltype* :select :in_part OwnerPart :all_3d)))
(setf RePnt (sd-vec-translate SFCenter (sd-plane-normal(sd-inq-geo-props YFace :Dest-space :global)) (- (sd-call-cmds (measure_dist  oint_surface SFCenter YFace)) (+ 4 (/ SNum 2)))))
;;The error occurred in the following code
(create_custom_feature mach_adv_library_countersunk_throughhole :action :create
:sel_face SFace
:cen_pnt RePnt
:axis (sd-plane-normal(sd-inq-geo-props SFaces :Dest-space :global))
:Drill_dia SNum
:chamfer_depth 0
:chamfer_angle 90
:back_chamfer_depth 0
:back_chamfer_angle 90
:name "hole")
Thanks
A mechanical engineer who loves to program
der_Wolfgang
Tastenhauer
Sehen Sie sich das Profil von der_Wolfgang an!   Senden Sie eine Private Message an der_Wolfgang  Schreiben Sie einen Gästebucheintrag für der_Wolfgang
● PE6+8@home
● W10 Pro Build19044.2364
● Drafting V20.1+4
● Modeling V20.1+4
erstellt am: 15. Jul. 2021 11:38    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für renchaoroy 10 Unities + Antwort hilfreich
your command recording isn't accurate enough, I think.
create_custom_feature is just a UI-wrapper which opens the custom feature browser. No need to do so when calling programmatially.
change
Code:
to
Code:
(mach_adv_library_countersunk_throughhole :action :create
and better use a sd-call-cmds around it ...
Code:
(sd-call-cmds (mach_adv_library_countersunk_throughhole :action :create
I did not execute that code.
Firefox ESRJava Forum Stuttgart JUGS ● OSD Hilfeseite (de) / help page (en)NotePad++BuFDi
