  PTC Creo Elements/Direct Modeling
  [English] Annotation 2008 crashes in Windows 10
Autor Thema:  [English] Annotation 2008 crashes in Windows 10 (660 / mal gelesen)
cacciatorino
Sehen Sie sich das Profil von cacciatorino an!   Senden Sie eine Private Message an cacciatorino  Schreiben Sie einen Gästebucheintrag für cacciatorino
Solid Edge ST9 Win7-64
Modeling V16-17-18 Win7-64
Salome 6.4 Code_Aster 11
erstellt am: 20. Sep. 2017 08:03    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
After upgrading from windows 7 to windows 10 I'm facing with the issue of CoCreate 2d module that crashes immediately every time that I try to insert a parametric symbol (roughness, shape tolerances, etc) or when I try to edit the properties of a dimension. All other basic operations seem to work normally: create views, create section views, etc. Things go well when I import static symbols too, such as sample-texts, symbols without parameters, etc.
The 3d module works perfectly with Win-10, and actually it seems faster if compared to the same hardware but running on Win-7.
the issue is not dependant on user privileges (already tried as admin user) and it is not affected by the compatibility settings (already tried with 7 or vista compatibility).
Any suggestions other than roll-back to Seven? I'm stuck on CoCreate 2008 due to a customer request.
Bests, Alessandro.
