Code:
Public Sub DecalFeature()
' ***Change path to point to the desired bmp file.
Dim strImagePath As String
strImagePath = "C:\Temp\Test.bmp" ' Create a new part document, using the default part template.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
' Create a new sketch on the X-Y work plane.
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Set a reference to the transient geometry object.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
Dim oCenter As Point2d
Set oCenter = oTransGeom.CreatePoint2d(0, 0)
' Create a sketch circle
Dim oCircle As SketchCircle
Set oCircle = oSketch.SketchCircles.AddByCenterRadius(oCenter, 1)
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
' Create a base extrusion 4 cm thick.
Dim oExtrudeDef As ExtrudeDefinition
Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(1, kPositiveExtentDirection)
Dim oExtrude As ExtrudeFeature
Set oExtrude = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
' Create a new sketch on the Y-Z work plane.
Dim oDecalSketch As PlanarSketch
Set oDecalSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(1))
' Create the placement point for the image.
Dim oPoint As Point2d
Set oPoint = oTransGeom.CreatePoint2d(0, 4)
' Add a sketch image
Dim oSketchImage As SketchImage
Set oSketchImage = oDecalSketch.SketchImages.Add(strImagePath, oPoint)
' Get the cylindrical face of the extrude
Dim oFace As Face
Set oFace = oExtrude.SideFaces.Item(1)
' Create a decal feature that wraps onto the cylindrical face.
Dim oDecal As DecalFeature
Set oDecal = oCompDef.Features.DecalFeatures.Add(oSketchImage, oFace, True)
End Sub
