Code:
Option Explicit On
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32Class ClsSelect
' Declare the event objects
Private WithEvents oInteractEv As InteractionEvents
Private WithEvents oSelectEv As SelectEvents
' Declare a flag that's used to determine when selection stops.
Private bStillSelecting As Boolean
'VB.net Vorschlag aus cad.de -vb.net
'Public Function Pick(ByVal filter As SelectionFilterEnum, ByVal oAppOselect As Application) As Object
Public Function Pick(filter As SelectionFilterEnum) As Object
Dim mApp As Inventor.Application
mApp = Marshal.GetActiveObject("Inventor.Application")
bStillSelecting = True
'Laut cad.de über oAppOSelect
' Create an InteractionEvents object.
'oInteractEv = mApp.CommandManager.CreateInteractionEvents
' Ensure interaction is enabled.
oInteractEv.InteractionDisabled = False
' Define that we want select events
oInteractEv.SelectionActive = True
' Set a reference to the select events.
oSelectEv = oInteractEv.SelectEvents
' Set the filter using the value passed in.
oSelectEv.AddSelectionFilter(filter)
' Start the InteractionEvents object.
'Hier ändert sich der Mauszeiger zum Auswahl Cursor
'es lässt sich aber keine Fläche auswählen
oInteractEv.Start()
'MsgBox("Select the face you want to measure")
'Mit Pick lässt sich eine Fläche auswählen, aber
'ich weiß nicht wie man sie einem OBjekt zuweist, um
'die Fläche weiter verwenden zu können
'mApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kAllPlanarEntities, "Pick planar")
' Loop until a selection is made.
Do While bStillSelecting
'Was macht DoEvents()?
Try
System.Windows.Forms.Application.DoEvents()
'mApp.UserInterfaceManager.DoEvents()
Catch ex As Exception
MsgBox(ex.Message)
End Try
Loop
' Get the selected item. If more than one thing was selected,
'get the first item and ignore the rest.
Dim oSelectedEnts As ObjectsEnumerator
oSelectedEnts = oSelectEv.SelectedEntities
If oSelectedEnts.Count > 0 Then
Pick = oSelectedEnts.Item(1)
Else
Pick = Nothing
End If
' Stop the InteractionEvents object.
oInteractEv.Stop()
' Clean up.
oSelectEv = Nothing
oInteractEv = Nothing
End Function
Private Sub oInteractEvents_OnTerminate()
' Set the flag to indicate we're done.
bStillSelecting = False
End Sub
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelectEv.OnSelect
End Sub
End Class
