Code:
Public Sub BOMExport()
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument ' Set a reference to the BOM
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
' Set a reference to the "Structured" BOMView
Dim oStructuredBOMView As BOMView
Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
oStructuredBOMView.Export "C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat
' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
' Set a reference to the "Parts Only" BOMView
Dim oPartsOnlyBOMView As BOMView
Set oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
oPartsOnlyBOMView.Export "C:\temp\BOM-PartsOnly.xls", kMicrosoftExcelFormat
End Sub
