Code:
Public Sub ProjectingAcrossParts() ' Set a reference to the assembly component definition.
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Get references to two occurrences.
' This arbitrarily gets the first and second occurrence.
Dim oOcc1 As ComponentOccurrence
Set oOcc1 = oAsmCompDef.Occurrences.Item(1)
Dim oOcc2 As ComponentOccurrence
Set oOcc2 = oAsmCompDef.Occurrences.Item(2)
' Create a sketch on the first part.
Dim oSketch1 As PlanarSketch
Set oSketch1 = oOcc1.Definition.Sketches.Add(oOcc1.Definition.WorkPlanes(1))
' Set a reference to the transient geometry collection.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
' Create a sketch line on the sketch.
Dim oSketchLine1 As Object
Set oSketchLine1 = oSketch1.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(0, 0), _
oTransGeom.CreatePoint2d(4, 0))
' Because we need the sketch line in the context of the assembly
' we need to create a proxy for the sketch line. The proxy
' represents the sketch line in the context of the assembly.
Dim oSketchLine1Proxy As Object
Call oOcc1.CreateGeometryProxy(oSketchLine1, oSketchLine1Proxy)
' Create a sketch on the second part.
Dim oSketch2 As PlanarSketch
Set oSketch2 = oOcc2.Definition.Sketches.Add(oOcc2.Definition.WorkPlanes(1))
' Create a proxy for the sketch in the second part.
Dim oSketch2Proxy As PlanarSketchProxy
Call oOcc2.CreateGeometryProxy(oSketch2, oSketch2Proxy)
' Project the line in the sketch in the first
' part to the sketch in the second part
Dim oSketchLine2Proxy As SketchLineProxy
Set oSketchLine2Proxy = oSketch2Proxy.AddByProjectingEntity(oSketchLine1Proxy)
End Sub
