Hallo, habe z.Z. nur 2009 vorOrt,
Invenbtor-Hilfe/Weitere Ressourcen/Programmierhilfe (mk:@MSITStore :\Inventor%202009\Inventor%202009\Pss\ADMAPI_13_0.chm::/API_Home.htm) und dann unter Samples (Sample Code) sind eine ganze Menge VBA Beispiele.
---edit anfang ----
Public Sub TestFileDialog()
' Create a new FileDialog object.
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
' Define the filter to select part and assembly files or any file.
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
' Define the part and assembly files filter to be the default filter.
oFileDlg.FilterIndex = 1
' Set the title for the dialog.
oFileDlg.DialogTitle = "Open File Test"
' Set the initial directory that will be displayed in the dialog.
oFileDlg.InitialDirectory = "C:\Temp"
' Set the flag so an error will be raised if the user clicks the Cancel button.
oFileDlg.CancelError = True
' Show the open dialog. The same procedure is also used for the Save dialog.
' The commented code can be used for the Save dialog.
On Error Resume Next
oFileDlg.ShowOpen
' oFileDlg.ShowSave
' If an error was raised, the user clicked cancel, otherwise display the filename.
If Err Then
MsgBox "User cancelled out of dialog"
ElseIf oFileDlg.FileName <> "" Then
MsgBox "File " & oFileDlg.FileName & " was selected."
End If
End Sub
---- edit ende ----
SEHER
www.inventor-tools.de
[Diese Nachricht wurde von SEHER am 04. Nov. 2011 editiert.]
