Hallo Zorro,
hier der Code aus dem Beispiel:
Public Sub DrawingSketchFill()
' Set a reference to the active document. This assumes it
' is a drawing document.
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Create a sketch on the active sheet
Dim oSketch As DrawingSketch
Set oSketch = oDoc.ActiveSheet.Sketches.Add
' Put the sketch in edit mode
oSketch.Edit
' Set a reference to the transient geometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Draw a circle in the sketch.
Dim oCircle1 As SketchCircle
Set oCircle1 = oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(10, 30), 2)
' Create a collection and add the circle.
Dim oCollection1 As ObjectCollection
Set oCollection1 = ThisApplication.TransientObjects.CreateObjectCollection
oCollection1.Add oCircle1
' Create a profile from the first circle
Dim oProfile1 As Profile
Set oProfile1 = oSketch.Profiles.AddForSolid(False, oCollection1)
' Create a fill region based on the layer color.
Call oSketch.SketchFillRegions.Add(oProfile1)
' Draw another circle in the sketch.
Dim oCircle2 As SketchCircle
Set oCircle2 = oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(30, 30), 2)
Dim oCollection2 As ObjectCollection
Set oCollection2 = ThisApplication.TransientObjects.CreateObjectCollection
oCollection2.Add oCircle2
' Create a profile from the second circle
Dim oProfile2 As Profile
Set oProfile2 = oSketch.Profiles.AddForSolid(False, oCollection2)
' Create a transient color object.
Dim oColor As Color
Set oColor = ThisApplication.TransientObjects.CreateColor(255, 0, 0) 'Red
' Create a fill region with an override color.
Call oSketch.SketchFillRegions.Add(oProfile2, oColor)
' Exit from editing the sketch.
oSketch.ExitEdit
End Sub
Grüsse,
Paul
www.morecam.ch
www.thinkcad.de
