Thema: Testforum ist nur zum Testen! (118221 mal gelesen)
Proxy Moderator Stateless-DHCP v6-Paketfragmentierer
 Beiträge: 300 Registriert: 13.11.2003 (entmake (entget (entlast))) Pro-Version 2.0
erstellt am: 16. Jan. 2004 22:03 <-- editieren / zitieren -->
Zitat: Original erstellt von StefanBerlitz: Dir und allen Anderen auch! Was hab ich verpasst? Was ist geschafft? Oder geht's drum, wer die größte Zahl kennt ... au fein, da kann ich mitmachen: 1.567.234.886 ist die größte Zahl, die ich persönlich kenne. Irgendjemand mehr? Ciao, Stefan
31.415.926.535.8979.323.846.264.338.327.950.288.419.716.939.937.510.582.097.494.459.230.781.640.628.620.899.862.803.482.534.211.706.798.214.808.651.32.823.066.470.938.446.095.50 5.822.317.253.594.081.284.811.174.502.841.027.019.3852.110.555.964.462.294.895.493.038.196.442.881.097.566.593.344.612.847.564.823.378.678.316.527.120.190.914.564.856.692.346.034.8 61.045.432.664.821.339.360.726.024.914.127.372.458.700.660.631.558.817.488.152.092.096.282.925.409.171.533.436.789.259.036.001.133.053.054.882.046.652.138.414.695.194.151.160.943.3 05.727.036.575.959.195.309.218.611.738.193.261.179.310.511.854.807.446.237.996.274.956.735.188.575.272.489.122.793.818.301.194.912.983.367.336.244.065.664.308.602.139.494.639.522.4 73.719.070.217.986.094.370.277.053.921.717.629.317.675.238.467.481.846.766.940.513.200.056.812.714.526.356.082.778.577.134.275.778.960.917.363.717.872.146.844.090.122.495.343.014.6 54.958.537.105.079.227.968.925.892.354.201.995.611.212.9021.960.864.034.418.159.813.629.774.771.309.960.518.707.211.349.999.998.372.978.049.951.059.7317.328.160.963.185.950.244.594 .553.469.083.026.425.223.082.533.446.850.352.619.311.881.710.100.031.378.387.528.865.875.332.083.814.206.171.776.691.473.035.982.534.904.287.554.687.311.595.628.638.823.537.875.937 .519.577.818.577.805.321.712.268.066.130.019.278.766.111.959.092.164.201.989 Gewonnen ? dann kann z.B. der nächter prüfen wieviel mal PI multipliziert worden ist  ------------------ "Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?" Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Bene Moderator ich putz' hier nur
 Beiträge: 5755 Registriert: 10.04.2002 減速材
erstellt am: 16. Jan. 2004 21:35 <-- editieren / zitieren -->
Und ich dachte ich hätte ne Schraube locker ts,ts,ts.Hut ab! Wie gut das genau dazu das Testforum da ist!  ------------------ ciao bene "Bloody Stupid Johnson" Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
StefanBerlitz Moderator IT Admin (CAx)
 Beiträge: 590 Registriert: 02.03.2000 SunZu sagt: Analysiere die Vorteile, die du aus meinem Ratschlag ziehst. Dann gliedere deine Kräfte entsprechend und mache dir außergewöhnliche Taktiken zunutze.
erstellt am: 16. Jan. 2004 15:52 <-- editieren / zitieren -->
Dir und allen Anderen auch!Aber ... Zitat: 0 - geschafft!
Was hab ich verpasst? Was ist geschafft? Oder geht's drum, wer die größte Zahl kennt ... au fein, da kann ich mitmachen: 1.567.234.886 ist die größte Zahl, die ich persönlich kenne. Irgendjemand mehr?  Ciao, Stefan ------------------ Inoffizielle deutsche SolidWorks Hilfeseite http://solidworks.cad.de KLAMM? Was ist KLAMM? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
ole Plauderprofi V.I.P. h.c. Schlossherr, sie schrieben's bei der Ausbildung nur ständig verkehrt
 Beiträge: 6324 Registriert: 02.08.2002 Kein Plan, kein System - trotzdem wichtig: :( z-Fanclub :(
erstellt am: 16. Jan. 2004 15:02 <-- editieren / zitieren -->
0 - geschafft!Also werde ich jetzt testen, ob mir der Beginn des WE heute genauso viel Befriedigung bringt, wie immer. Bei sehr geringer Fehlertoleranz und der auftretenden Schwierigkeit, seine volle Konzentration zum Feierabend unsinnigen Tests zu widmen, ist nicht auszuschließen, dass dieser Test am nächsten Freitag wiederholt wird. Was ich eigentlich sagen wollte, oder auch schiebenderweise, langer Rede kurzer Sinn: Allen ein schönes WE. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 14:34 <-- editieren / zitieren -->
N° 52------------------ "Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?" Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Jörg W Moderator Maschinenbautechniker und CAD Admin
 Beiträge: 2172 Registriert: 12.07.2001 Hier ist das Tsetfurom. Hier darf auch geplaudert werden.
erstellt am: 16. Jan. 2004 14:24 <-- editieren / zitieren -->
Das ist der 51 BeitragEDIT: Testergebnis: Also, das Aufteilen auf mehrere Seiten und die Sortierung der Beiträge wird mit dem 51. Beitrag durchgeführt. EDIT ENDE
------------------ Pfürti Jörg W Meine bescheidene Homepage Na, Heute schon geklammt??? [Diese Nachricht wurde von Jörg W am 16. Jan. 2004 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 14:23 <-- editieren / zitieren -->
Hallo,Das ist jetzt ein Test ob sich ab dem 50. Beitrag die Sortierung der Beiträge ändert. ------------------ Pfürti Jörg W Meine bescheidene Homepage Na, Heute schon geklammt??? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 14:19 <-- editieren / zitieren -->
9929------------------ "Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?" Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 11:59 <-- editieren / zitieren -->
9930Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 11:47 <-- editieren / zitieren -->
Römer hätten I II II IV V.... gezählt. Hier trifft sich, wer die Sekunden bis zum Feierabend zählt (Kann auch nicht sein, müsste dann in absteigender Reihenfolge passieren )Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
