 | Lenovo stellt Hochleistungs-Workstations der nächsten Generation vor und kündigt den weltweit ersten 1.000Wh/L Silicon-Anode-Akku für Notebooks und Workstations an, eine Pressemitteilung
Thema: Testforum ist nur zum Testen! (118216 mal gelesen)
Proxy Moderator Stateless-DHCP v6-Paketfragmentierer
 Beiträge: 300 Registriert: 13.11.2003 (entmake (entget (entlast))) Pro-Version 2.0
erstellt am: 16. Jan. 2004 22:03 <-- editieren / zitieren -->
Zitat: Original erstellt von StefanBerlitz: Dir und allen Anderen auch! Was hab ich verpasst? Was ist geschafft? Oder geht's drum, wer die größte Zahl kennt ... au fein, da kann ich mitmachen: 1.567.234.886 ist die größte Zahl, die ich persönlich kenne. Irgendjemand mehr? Ciao, Stefan
31.415.926.535.8979.323.846.264.338.327.950.288.419.716.939.937.510.582.097.494.459.230.781.640.628.620.899.862.803.482.534.211.706.798.214.808.651.32.823.066.470.938.446.095.50 5.822.317.253.594.081.284.811.174.502.841.027.019.3852.110.555.964.462.294.895.493.038.196.442.881.097.566.593.344.612.847.564.823.378.678.316.527.120.190.914.564.856.692.346.034.8 61.045.432.664.821.339.360.726.024.914.127.372.458.700.660.631.558.817.488.152.092.096.282.925.409.171.533.436.789.259.036.001.133.053.054.882.046.652.138.414.695.194.151.160.943.3 05.727.036.575.959.195.309.218.611.738.193.261.179.310.511.854.807.446.237.996.274.956.735.188.575.272.489.122.793.818.301.194.912.983.367.336.244.065.664.308.602.139.494.639.522.4 73.719.070.217.986.094.370.277.053.921.717.629.317.675.238.467.481.846.766.940.513.200.056.812.714.526.356.082.778.577.134.275.778.960.917.363.717.872.146.844.090.122.495.343.014.6 54.958.537.105.079.227.968.925.892.354.201.995.611.212.9021.960.864.034.418.159.813.629.774.771.309.960.518.707.211.349.999.998.372.978.049.951.059.7317.328.160.963.185.950.244.594 .553.469.083.026.425.223.082.533.446.850.352.619.311.881.710.100.031.378.387.528.865.875.332.083.814.206.171.776.691.473.035.982.534.904.287.554.687.311.595.628.638.823.537.875.937 .519.577.818.577.805.321.712.268.066.130.019.278.766.111.959.092.164.201.989 Gewonnen ? dann kann z.B. der nächter prüfen wieviel mal PI multipliziert worden ist  ------------------ "Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?" Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Bene Moderator ich putz' hier nur
 Beiträge: 5995 Registriert: 10.04.2002 ich hatte mal Inventor...
erstellt am: 16. Jan. 2004 21:35 <-- editieren / zitieren -->
StefanBerlitz Moderator IT Admin (CAx)
 Beiträge: 682 Registriert: 02.03.2000 SunZu sagt: Analysiere die Vorteile, die du aus meinem Ratschlag ziehst. Dann gliedere deine Kräfte entsprechend und mache dir außergewöhnliche Taktiken zunutze.
erstellt am: 16. Jan. 2004 15:52 <-- editieren / zitieren -->
ole Quasselprofi V.I.P. h.c. Schlossherr, sie schrieben's bei der Ausbildung nur ständig verkehrt
 Beiträge: 11403 Registriert: 02.08.2002 Kein Plan, kein System - trotzdem wichtig: S-Fanclub
erstellt am: 16. Jan. 2004 15:02 <-- editieren / zitieren -->
0 - geschafft! Also werde ich jetzt testen, ob mir der Beginn des WE heute genauso viel Befriedigung bringt, wie immer. Bei sehr geringer Fehlertoleranz und der auftretenden Schwierigkeit, seine volle Konzentration zum Feierabend unsinnigen Tests zu widmen, ist nicht auszuschließen, dass dieser Test am nächsten Freitag wiederholt wird. Was ich eigentlich sagen wollte, oder auch schiebenderweise, langer Rede kurzer Sinn: Allen ein schönes WE. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 16. Jan. 2004 14:34 <-- editieren / zitieren -->
Jörg W Moderator Maschinenbautechniker und CAD Admin
 Beiträge: 2210 Registriert: 12.07.2001 Hier ist das Tsetfurom. Hier darf auch geplaudert werden.
erstellt am: 16. Jan. 2004 14:24 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 14:23 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 14:19 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 11:59 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 11:47 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 11:42 <-- editieren / zitieren -->
Die spinnen . . . . . . . . . . . . . . . . . ....... die Römer, oder was für Wahnsinnige tummeln sich hier  ------------------ Viele Grüße wera [Diese Nachricht wurde von WERA am 16. Jan. 2004 editiert.] |
erstellt am: 16. Jan. 2004 10:59 <-- editieren / zitieren -->
cadffm Moderator 良い精神
 Beiträge: 1097 Registriert: 03.06.2002
erstellt am: 16. Jan. 2004 10:54 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:39 <-- editieren / zitieren -->
Ralf Tide Moderator R.E.D.
 Beiträge: 1010 Registriert: 06.08.2001 Hier könnte irre Werbung stehen... .-)
erstellt am: 16. Jan. 2004 10:33 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:28 <-- editieren / zitieren -->
 Beiträge: 1097 Registriert: 03.06.2002 System: F1 und Google
erstellt am: 16. Jan. 2004 10:27 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:26 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:25 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:24 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:23 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:22 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:20 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:17 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:16 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:15 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:14 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:13 <-- editieren / zitieren -->
erstellt am: 16. Jan. 2004 10:03 <-- editieren / zitieren -->
erstellt am: 15. Jan. 2004 18:23 <-- editieren / zitieren -->
Zitat: Original erstellt von ole: BTW: Ich suche wegen dieser unangebrachten Korinthenka****** dringend einen link zu einem Bild eines Korinthenbaumes.
Frag mal bei Korinthenkacker-Club.de nach, vielleicht haben die bessere Beziehungen um an Bilder ranzukommen.  ------------------ "Lisp?!?! Why the Hell did you pick the most arcane, obscure, and hopelessly-rooted-in-the-computer-science-department language in the world for an AutoCAD programming language?" Read the whole story: The Autodesk File ca. 890 Seiten | 7500 KB PDF Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
startrek Moderator Architekt
 Beiträge: 859 Registriert: 13.02.2003 I saw Elvis - he sat between me and Bigfoot in the UFO.
erstellt am: 15. Jan. 2004 18:14 <-- editieren / zitieren -->
Hallo Ralf, also, ähm, ja ... bin ja eigentlich auch nicht so , aber, haust' jetzt nicht doch was bissel durcheinander? Oder hast Dich 'verzitatiert' Vielleicht blick' ich's ja auch momentan nicht so lg Nancy [Diese Nachricht wurde von startrek am 15. Jan. 2004 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 15. Jan. 2004 15:53 <-- editieren / zitieren -->
Hallo Bene, freut mich das auch anderen die neue deutsche Rechtschreibung in den Augen weh tut (nicht nur mir ) [edit]15. Jan. 2004 19:40 OK Nancy, Du hast Recht . Wenn man's (sogar ich ) etwas isoliert liest und nicht direkt im Zusammenhang ist's bestimmt schwierig . Um's noch'n bischen komplizierter zu machen, editier ich meinen Beitrag und erstelle keinen Neuen
- Das mit den Augenschmerzen bezieht sich auf Vilosovieh.
- Die im nachfolgenden Zitat vage Vermutung ist IMHO die kurz darauf zitierte unangebrachte Korinthenka....
- Der anschließend folgende Link war eigentlich dazu gedacht das sich dort Korinthenkacker austauschen. Von diesen Menschen kann man sicherlich viel interessantes erfahren
Noch Fragen?  Ich versprech' das ich mir bei den nächsten postings vielleicht doch das ein oder andere verkneif . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . oder auch nicht  [/edit] Zitat: Original erstellt von Bene: Das ist eine sehr vage Vermutung - nach Erstellen von threads in anderen Foren ist dieser thread hier keineswegs...Ich suche wegen dieser unangebrachten Korinthenka...
Hier gibt's übrigens ein gaaaaanz spezielles Forum: http://www.korinthenkacker-club.de/ vielleicht ist ja was für Dich dabei Beste Grüße & bis demnäx Ralf ------------------ KLAMM? Was ist KLAMM? [Diese Nachricht wurde von Ralf Tide am 15. Jan. 2004 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 15. Jan. 2004 15:35 <-- editieren / zitieren -->
erstellt am: 15. Jan. 2004 15:24 <-- editieren / zitieren -->
erstellt am: 15. Jan. 2004 15:11 <-- editieren / zitieren -->
erstellt am: 15. Jan. 2004 09:08 <-- editieren / zitieren -->
Ich bin begeistert bei Sachen die es gbt, obwohl es sie garnicht geben dürfte  . Bin ein norddeutsches Unkraut mit völliger Unkenntnis der heimischen Flora, wenn sie nicht gerade in Blumenläden erhältlich ist  . Der nächste Urlaub wird ins Gebirge geplant: Dösen unterm Korinthenbaum bis mir die Felsenbirnen in den Mund wachsen. PS: Hat noch jemand ein Bild vom Palast einer Sultanine? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 15. Jan. 2004 08:46 <-- editieren / zitieren -->
erstellt am: 15. Jan. 2004 08:33 <-- editieren / zitieren -->
Dem kann man nur abhelfen wenn man in einem anderen Thread einen neuen Beitrag schreibt.
Das ist eine sehr vage Vermutung - nach Erstellen von threads in anderen Foren ist dieser thread hier keineswegs...... BTW : Ich suche wegen dieser unangebrachten Korinthenka****** dringend einen link zu einem Bild eines Korinthenbaumes . Zitat:
Filosofi
Bin noch nicht mal wach und schon halb erblindet. Ist das die neue Rechtschreibung oder ein Hundename? Das liest sich wie Schifffahrt mit 5xf oder um es neudeutsch auszudrücken: vielleicht auch shipfart. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 15. Jan. 2004 07:12 <-- editieren / zitieren -->
Zitat: Original erstellt von Bene: ...Ist der Thread wieder oben, nur durch Philosphie?...
Hallo Bene, pragmatisch: nur durch einen neuen Beitrag kommt der Thread ganz nach oben. Mit Filosofi hat das nix zu tun. Dem kann man nur abhelfen wenn man in einem anderen Thread einen neuen Beitrag schreibt.  Beste Grüße Ralf ------------------ KLAMM? Was ist KLAMM? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jan. 2004 17:29 <-- editieren / zitieren -->
Gute Geister gibt es wenigsten 2, okay. Einer ist eher blau, trinkt aber nicht, der andere ist eher rot, dabei ist ihm nichts peinlich. Wieso eigentlich? Und macht ein umstürzender Baum auch ein Geräusch, wenn keiner da ist es zu hören? Ist dieses Forum real, oder Stelle ich es mir nur vor? Ist der Thread wieder oben, nur durch Philosphie? ------------------ ciao bene "Bloody Stupid Johnson" Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jan. 2004 08:38 <-- editieren / zitieren -->
Hoppla, wie die Zeiten sich ändern: Gab mal Zeiten, in denen man Aladin heißen musste, um einem guten Geist zu begegnen - hier treiben die sich rudelweise umher :P. Gemeint war wirklich Stefan - gute Geister mit hochrotem Kopf und grimmigem Gesicht sind für mich was völlig Neues . Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jan. 2004 08:35 <-- editieren / zitieren -->
Ups, zu früh gefreut, als Moderator kann man nur in "seinen" Brettern eine Ankündigung erstellen. Also müssen wir doch erst mal Heiko davon überzeugen, hier den Mod zu machen (soll erdas doch dann Andreas und Albert erklären  ), dann kann er ja eine Ankündigung machen. Bis dahin können wir ja den Vorschlag von Bene weiter verfolgen  Stefan ------------------ Inoffizielle deutsche SolidWorks Hilfeseite http://solidworks.cad.de KLAMM? Was ist KLAMM? Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 14. Jan. 2004 08:32 <-- editieren / zitieren -->
Puh, und ich hab schon gedacht ich wäre gemeint  Also bevor Nancy Bene's Rechner mit eine paar neumodischen Scripten zerbessert kann ich ja vielleicht wirklich einfach wie gerhardt vorgeschlagen hat eine gepinnte Ankündigung oben ins Brett machen. Aber ihr müßt den Jungs und Mädels, die hier testen, auch mal 'ne Chance geben, den Beitrag dann ins echte Brett zu posten. Manchen testen ihre Originalposts, dann muss man mal ein Blick in deren Profil riskieren um zu schauen, ob derselbe Post nicht vielleicht doch schon im "echten" Brett gelandet ist.  Und bei denen, die dann trotz Ankündigung und anderen Threads hier immer noch nicht im richtigen Brett gepostet haben können wir ja weiter auf die Sprünge helfen ... apropos, wo ist eigentlich helferlein? Ciao, Stefan
guter_geist Mitglied Anwendungsberater
 Beiträge: 392 Registriert: 24.02.2003
erstellt am: 13. Jan. 2004 16:12 <-- editieren / zitieren -->
WER HAT MICH GERUFEN??? Zitat: Original erstellt von ole: Mein Vorschlag, der mir womöglich den Zorn eines guten Geistes einbringt : Bene schreibt ein script, dass alle 2sec einen neuen Beitrag postet .Meine Kritik: Bene hat nicht getestet, sondern einen Verbesserungsvorschlag gemacht - also eindeutig im falschen Forum hier .
------------------ Der gute Geist "Gilde der Erfinnder" Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
