| | | Webinar für CAD-Konstrukteure im Metallbau: Industrietreppen, Balkone, Geländer in einer nahtlosen 2D- und 3D-CAD-Umgebung |
Autor(20117)
Thema: simulating milling of semi-cylinder (621 mal gelesen)
hayes78 Mitglied Engineer
Beiträge: 5 Registriert: 21.01.2010
erstellt am: 28. Jan. 2010 10:03 <-- editieren / zitieren --> Unities abgeben:
Hello, I'm trying to mill a half cylinder out in Mega-CAD 2009, I've drawn it, revolved it, created the raw material etc. When I create the NC code an Simulate it, its doesn't seem to see the semi-circle, it simulats the cutting of two flat sides tpaered at an angle and a flat base. if tried a number of differnt tools and also tried using the finishing z constant command but with no luck. Any suggestion or help would be much appreciated. Thanks Clive Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Crash Test Dummy Mitglied Serviceleiter
Beiträge: 135 Registriert: 03.02.2008 Windows Vista 64 Intel Xoen 2.27GHz 12 GB RAM Nividia Quadro FX 3800 MegaCAD 2010 Mega NC 2010 Megagenial 2010 Kinematik
erstellt am: 29. Jan. 2010 08:41 <-- editieren / zitieren --> Unities abgeben: Nur für hayes78
Hi Clive, can you post the file on this site and I'll take a look at it. Change the file extension to .txt as you can't post .PRT on this forum. Are you using MEGA NC?? We use Mega NC and it caused us a few problems to start with but if you stick with it it will all work out in the end. Conrad ------------------ To be born english is to have won the lottery of life! :-) Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 29. Jan. 2010 11:59 <-- editieren / zitieren --> Unities abgeben:
Hello Conrad, I was messing around with yesterday afternoon and it clicked what i had done, I had the Chord resolution set to zero, I changed this to 0.01mm and that did the trick, Cheers, Clive Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
| Anzeige.:
