Thema: PTC Creo konvertiert manchmal in dwg/dxf nicht. (1402 / mal gelesen)
Mars 11 Mitglied
Beiträge: 14 Registriert: 29.03.2010
erstellt am: 06. Apr. 2020 19:14 <-- editieren / zitieren --> Unities abgeben:
PTC Creo Elements/Direkt Drafting 19.0 konvertiert machmal in dxf/dwg nich. Ich habe die Logdatei angefügt. Habe sehr wenige kentnisse. Kann mir jemand helfen? Danke im Voraus MI to DWG translation log file PTC Creo Elements/Direct DXF/DWG Translator Release 19.0 (build 1071.18) dxfdwg ------------------------------------------------------- SourceDirPath ./ DestinDirPath ./ KanjiTranslate OFF EnableLegacyEncoding OFF RecordByLayerInfo OFF CustomUnits ON Units mm UnitsScale 1 ConvertMIDimensionsToGeometry OFF ExplodeDXFDimensions OFF KeepAttributesWithPart OFF StartSection DXF to MI Translator InternalHandseed PolymarkerType 2 OutputACADVersion AC1027 DXFDecimalPrecision 14 ReadAllLayoutData OFF TranslatePaperspace OFF LayoutName TranslateDXFPenLineSize 4 TranslateInvisibleLayers OFF TranslateDXFInvisibleEntities OFF TranslateMIInvisibleEntities OFF TranslateSubfixDimProp ON TranslateSuperfixDimProp ON ContourSnapGap 1e-012 HatchCloseContours ON KeepTopScale OFF TranslateMIPenLineSize 1 HighSplinePrecision OFF HatchToContours OFF CreateSplineFitPoints ON SplineControlPointTranslation OFF SVGDarkBackground ON MinimumHatchSpacingDensity 0 FontFilesPath ./ FontMapACADtoMI "ARIAL.TTF" "Arial" "hp_kanj2_c" 1.2 1.666 FontMapACADtoMI "ARIALBD.TTF" "Arial" "osd_default" 1.2 1.666 FontMapACADtoMI "ARIALUNI.TTF" "Arial_Unicode_Ms" "Arial_Unicode_Ms" 1.2 1.666 FontMapACADtoMI "complex.shx" "hp_block_v" "hp_kanj2_c" 0.95 1.666 FontMapACADtoMI "COUR.TTF" "Courier_New" "hp_kanj2_c" 0.75 1.666 FontMapACADtoMI "italic.shx" "hp_jasc_v" "hp_kanj2_c" 1.15 1.666 FontMapACADtoMI "simplex.shx" "osd_default3" "osd_default3" 0.95 1.666 FontMapACADtoMI "Tahoma.ttf" "Tahoma" "hp_kanj2_c" 1.25 1.666 FontMapACADtoMI "TIMES.TTF" "Times_New_Roman" "hp_kanj2_c" 1.03 1.666 FontMapACADtoMI "txt.shx" "osd_default" "osd_default" 0.9 1.666 FontMapMItoACAD "arial" "ARIAL.TTF" 1.2 "" 0 FontMapMItoACAD "arial_unicode_ms" "ARIALUNI.TTF" 1.2 "" 0 FontMapMItoACAD "courier_new" "COUR.TTF" 0.75 "" 0 FontMapMItoACAD "hp_block_c" "complex.shx" 1.39 "" 0 FontMapMItoACAD "hp_block_v" "complex.shx" 0.95 "" 0 FontMapMItoACAD "hp_d17_c" "simplex.shx" 1.24 "" 0 FontMapMItoACAD "hp_d17_v" "simplex.shx" 0.95 "" 0 FontMapMItoACAD "hp_i3098_c" "txt.shx" 1.07 "" 0 FontMapMItoACAD "hp_i3098_v" "txt.shx" 0.9 "" 0 FontMapMItoACAD "hp_jasc_c" "italic.shx" 1.24 "" 0 FontMapMItoACAD "hp_jasc_v" "italic.shx" 1.15 "" 0 FontMapMItoACAD "isocp" "isocp___.ttf" 0.77 "" 0 FontMapMItoACAD "osd_default" "txt.shx" 0.9 "" 0 FontMapMItoACAD "osd_default2" "txt.shx" 1.07 "" 0 FontMapMItoACAD "osd_default3" "simplex.shx" 0.95 "" 0 FontMapMItoACAD "tahoma" "Tahoma.ttf" 1.25 "" 0 FontMapMItoACAD "times_new_roman" "TIMES.TTF" 1.03 "" 0 FontMapMI2toACAD "hp_kanj2_c" "msmincho.ttc" 0.89 "MS Mincho" 32785 FontMapMI2toACAD "hp_kanji_c" "msmincho.ttc" 0.89 "MS Mincho" 32785 ArrowMapACADtoMI " " Arrow 1 ON ArrowMapACADtoMI "_ARCHTICK" Slash 1 OFF ArrowMapACADtoMI "_BOXBLANK" Arrow 1 OFF ArrowMapACADtoMI "_BOXFILLED" Arrow 1 ON ArrowMapACADtoMI "_CLOSED" Arrow 1 OFF ArrowMapACADtoMI "_CLOSEDBLANK" Arrow 1 OFF ArrowMapACADtoMI "_DATUMBLANK" Triangle 1 OFF ArrowMapACADtoMI "_DATUMFILLED" Triangle 1 ON ArrowMapACADtoMI "_DOT" Dot 1 ON ArrowMapACADtoMI "_DOTBLANK" Dot 1 OFF ArrowMapACADtoMI "_DOTSMALL" Dot 0.5 ON ArrowMapACADtoMI "_INTEGRAL" Slash 1 ON ArrowMapACADtoMI "_NONE" NoArrow 1 ON ArrowMapACADtoMI "_OBLIQUE" Slash 1 OFF ArrowMapACADtoMI "_OPEN" Jis 1 ON ArrowMapACADtoMI "_OPEN30" Jis 1 OFF ArrowMapACADtoMI "_OPEN90" Jis 1 ON ArrowMapACADtoMI "_ORIGIN" Dot 1 OFF ArrowMapMItoACAD NoArrow OFF "_NONE" 1 ArrowMapMItoACAD NoArrow ON "_NONE" 1 ArrowMapMItoACAD Arrow OFF "_CLOSED" 1 ArrowMapMItoACAD Arrow ON " " 1 ArrowMapMItoACAD Dot OFF "_ORIGIN" 1 ArrowMapMItoACAD Dot ON "_DOT" 1 ArrowMapMItoACAD Slash OFF "_OBLIQUE" 1 ArrowMapMItoACAD Slash ON "_OBLIQUE" 1 ArrowMapMItoACAD Triangle OFF "_DATUMBLANK" 1 ArrowMapMItoACAD Triangle ON "_DATUMFILLED" 1 ArrowMapMItoACAD Jis OFF "_OPEN30" 1 ArrowMapMItoACAD Jis ON "_OPEN30" 1 LinetypeMapACADtoMI "CENTER_DASH_DASH" CenterDashDash LinetypeMapACADtoMI "CONTINUOUS" Solid LinetypeMapACADtoMI "DASHED" Dashed LinetypeMapACADtoMI "DASH_CENTER" DashCenter LinetypeMapACADtoMI "DOTTED" Dotted LinetypeMapACADtoMI "DOT_CENTER" DotCenter LinetypeMapACADtoMI "LONG_DASHED" LongDashed LinetypeMapACADtoMI "PHANTOM" Phantom ------------------------------------------------- Fatal error (DWGDirect message: Invalid input) Some errors encountered during translation.
erstellt am: 06. Apr. 2020 20:04 <-- editieren / zitieren -->
Du schreibst „manchmal“ nicht. Dann scheint die Konfiguration in Ordnung zu sein und eher an der Bedienung liegen. Das Originalprogramm ist noch aus DOS-Zeiten. Also maximaler Dateiname und Pfadlänge 8 Buchstaben und keine Leerzeichen / Sonderzeichen. Manchmal muss man die Dateiendung mit angeben, manchmal ohne. Sind Schreibrechte auf dem gewünschten Pfad da ? Edit: Ist ins Blaue geraten, aber einen Versuch wert. Verwende eine Datei, die nicht ging. Kopiere sie direkt unter Laufwerk c:\ und benenne sie um in „test“ Versuche es nochmal.
[Diese Nachricht wurde von Julian72 am 07. Apr. 2020 editiert.] |
Mars 11 Mitglied
erstellt am: 06. Apr. 2020 21:07 <-- editieren / zitieren --> Unities abgeben:
Hallo Julian72 Die Projektzeichnungen werden bei uns mit GstarCAD vorbereitet. Die Daten sind mehrfachbenutzt. Ich öffne diese Zeichnung in Creo (ME10) und bearbeite weiter. Manche Daten mache ich eigenständig, da sonst die Bearbeitung sehr mühsam ist. Ab dann speichere ich als mi Datei weiter. Wenn ich mit meine Bearbeitung durch bin, möchte die Datei wieder als dwg/dxf speichern. Das klappt leider manchmmal nicht. Ich werde Morgen deine Vorschläge probieren. Danke Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Roman Mitglied
Beiträge: 674 Registriert: 16.01.2001 ME10 v20.4.1, Win10 SD v20.4.1, Win10 Windchill 12.02 Creo 8.0.2 in der Einführungsphase
erstellt am: 06. Apr. 2020 22:09 <-- editieren / zitieren --> Unities abgeben: Nur für Mars 11
Hi, "manchmal" sind bei uns Kundenzaichnungen im Paperspace angelegt. Dann muss der Parameter "TranslatePaperspace" auf "On" gesetzt werden. Allerdings kann man dann mit den Geometrien im ME10 nix anfangen. Aber für einen sauberen Ausdruck reichts. Roman Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
riesi Mitglied CAD-Admin, SolidWorks-Backend-Developer
Beiträge: 1016 Registriert: 06.05.2002 SolidWorks 2020-Sp5 OneSpaceDrafting V20.5 MS-Windows 10 Prof. 64Bit Core i7-6700 @ 3.40 GHz 32,00 GB RAM ATI WX 5100
erstellt am: 07. Apr. 2020 07:41 <-- editieren / zitieren --> Unities abgeben: Nur für Mars 11
Der DXF-Konverter kann keine Xrefs auflösen und 3D-Objekte, welche sich auch in DWGs manchmal befinden, konvertieren. Desweiteren hat der Probleme mit tief Verschachtelten Block-Strukturen. Mit V19 bist Du auch nicht mehr auf dem aktuellen Stand, wenn Du neuste DWG-Versionen bekommst. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Mars 11 Mitglied
erstellt am: 17. Apr. 2020 20:53 <-- editieren / zitieren --> Unities abgeben:
Ich habe die Baugruppen als Teil einzel in dwg gespeichert. Bis ich auf die Baugruppe gestossen bin, was nicht gespeichert wurde. Dann habe ich diese Baugruppe weiter untersucht und festgestellt, dass die Datei "Hatch" das verursacht hat. Hatch (mehrere) habe ich gelöscht, dann könnte ich in dwg speichern. Diese Hatch sind manchmal untereinander geschachtelt. Manuell danach suchen dauert sehr lange. Gibt es Möglichkeit, wie bei eigenstaendig machen der Gemeinsamen Dateien, in Befehlszeile ein Befehl geben und die Hatch sind gelöscht. Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
friedhelm at work Mitglied Techniker Aluminium Profile
Beiträge: 882 Registriert: 01.04.2003 Creo Elements Direct /Drafting 17+20.x ui classic-Tablett + Ribbon, Modeling 17-20.0,.2,.4,.5 Lizenz auf USB-Netzwerkadapter PE-Express 8 Win 10 Enterprise 64 @work Win 10 Pro 64 @home Notepad++,IrfanView,eDrawings, ....
erstellt am: 19. Apr. 2020 16:25 <-- editieren / zitieren --> Unities abgeben: Nur für Mars 11
Hallo Mars 11. In die Kommandolinie eingeben. Standard: DELETE_HATCH +Enter dann die Schraffur anklicken kennst du. Löscht alle Schraffuren im aktuellen Teil: DELETE_HATCH ALL CONFIRM END +Enter Löscht alle Schraffuren in der gesammten Zeichnung: DELETE_HATCH GLOBAL ALL END +Enter Hoffe dass du damit schon mal weiterkommst. Wäre natürlich besser wenn man wüsste, was an der Problem-Schraffur faul ist. Dann könnte man diesen "Fehler" global in der Zeichnung beheben ohne die Schraffuren zu löschen. Dazu wäre es gut, wenn du eine solche Zeichnung hochladen würdest. Dann noch ein Link zu einem Tip, der leider nicht bei älteren Versionen funktioniert, wie du dort lesen kannst. Was du verwendest weiss ich nicht, da auch du deine Systeminfo nicht ausgefüllt hast Zeichnung cleanen Egal, Hauptsache ihr bleibt gesund ------------------ Gruss Friedhelm Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 19. Apr. 2020 16:39 <-- editieren / zitieren --> Unities abgeben: Nur für Mars 11
Zitat: Original erstellt von riesi: Mit V19 bist Du auch nicht mehr auf dem aktuellen Stand, wenn Du neuste DWG-Versionen bekommst.
Bischen "out of toppic" In unserer Me10 v17 arbeitet der dxfdwg v20.2.1 als Aushilfe. Wir sind sehr mit ihm zufrieden Er wird wohl eine Festanstellung bekommen. ------------------ Gruss Friedhelm Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
