  Lisp
  Fas Decompiler&Obfuscator Project
Von Digital Twins bis Hochleistungs-Computing: PNY präsentiert seine Zukunftstechnologien für die Industrie von morgen, eine Pressemitteilung
Autor Thema:  Fas Decompiler&Obfuscator Project (9814 mal gelesen)
naxx
Sehen Sie sich das Profil von naxx an!   Senden Sie eine Private Message an naxx  Schreiben Sie einen Gästebucheintrag für naxx
erstellt am: 30. Okt. 2005 20:25    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
... after about 3 years I think can give this topic some bump up.
Have a look at http://lisp-decompiler-project.cjb.net/
all I added by now is 'fas-interpreter-alpha-08.zip'
Well it's still just some fas-byte-code-disassembler but now it adds some lisp snippets as comments to the disassembling and tries to recognise loop's alternatives and insert some space at the beginnings so it is nicer to read.
By now I improved opcode quality (unknown or wrong descriptive commands) for the Autolisp include (*.FSL) which are stored inside vllib.dll. I wonder why some of these opcodes that would improve execution speed were not used in 'normal' Fas files.
Even if I called this 'Lisp Decompiler Project' it's more about exploring lisp the reverse way from the binary to the user level. And also get out more about the Lisp-internals. Explorering the power of a simple stackmachine.
Knowing all about the lisp bytecode also means also you can optimise aswell as transform it. Think of the .NET obsucator for IDL or Java obsucator. There is no question that this is also possible with fas-file.
So please don't ask if this decompiles Fas to Lsp files? The answer is "NO". If you don't believe have a look at it and ask yourself what this output has to do with lisp.
If you're interested to take part in this open source project have a look at the infos at the site and mailto:cw2k@gmx.de.
