Code:
Sub CATMain()' Spec and Compass Off ?
Dim response
response = MsgBox ("Mit einem Klick auf OK beginnt das Makro seine Arbeit. Prüfen sie zuvor ob das Startmodell richtig befüllt ist.", vbOKCancel + vbInformation + vbDefaultButton2)
If response = vbOK Then
On Error resume next
Dim Window1
Set Window1 = CATIA.ActiveWindow
Dim WindowLayout1
WindowLayout1 = Window1.Layout
Window1.Layout = catWindowSpecsAndGeom
CATIA.StartCommand "CompassDisplayOn"
Else
Exit Sub
End If
Dim oGS As HybridBody
Dim sel As Selection
Set sel = CATIA.ActiveDocument.Selection
Set oGS = "Name=Prepare_part_Input_Part,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surface_analysis"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Porcupine_Curvature,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Inflection_area,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Gaussian,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Minimum_Curvature,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Connect Checker Analysis_Punktsteigkeit_G0,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Connect Checker Analysis_Tangentensteigkeit_G1,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Connect Checker Analysis_Kruemmungssteigkeit_G2,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Maximum_Curvature,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Limited,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Surfacic Curvature Analysis_Surfacic_Curvature_R10000,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Connect Checker Analysis_Surfacic_Curvature_R30000,all"
sel.Add oGS
oGS.Clear
Set oGS = "Name=Connect Checker Analysis_Surfacic_Curvature_R100000,all"
sel.Add oGS
oGS.Clear
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetShow catVisPropertyNoShowAttr
Catia.ActiveWindow.Viewers.item(1).CaptureToFile 1, "C:\Temp\temp_pic.jpg"
On error goto 0
' Set PowerPoint
Dim ppt
On Error Resume Next
Set ppt = GetObject (,"PowerPoint.Application")
If Err.Number = 0 Then
Err.Clear
Else
Set ppt = CreateObject("PowerPoint.Application")
PPT.Visible=True
Set Pres = PPT.Presentations.Open("G:\CATIA_Makro_Vorlage\PowerPoint_template.pptx")
on error resume next
End If
Set uNewS = ppt.ActivePresentation.slides.Add(ppt.ActivePresentation.slides.count + 1 , 3)
If (err) then
Set uNewP = ppt.Presentations.Add(True)
ppt.Visible = true
ppt.windowstate = 2
Set uNewS = uNewP.slides.Add(uNewP.slides.count + 1 , 3)
else
Set uNewP = ppt.ActivePresentation
End if
On error goto 0
uNewS.Layout = 12
uuInput = 1
uPictureFormat = 0
call ppt.Windows.item(1).Activate
call pasteGraphic( ppt, uNewP, ab, uMultiGraph )
CATIA.ActiveWindow.ActiveViewer.FullScreen = false
End Sub
Set oDoc = CATIA.ActiveDocument
Set oCams = oDoc.Cameras
Set oCam = oCams.Item(2)
Set oViewPoint = oCam.Viewpoint3D
Set oSpecWindow = CATIA.ActiveWindow
Set oViewer = oSpecWindow.ActiveViewer
oViewer.Viewpoint3D = oViewPoint
oViewer.Reframe
Public Function pasteGraphic( ppt, uNewP, ab, uuInput )
ppt.ActiveWindow.view.GotoSlide(uNewP.slides.count)
fullname = "C:\Temp\temp_pic" & uuInput-1 & ".jpg"
If uuInput < 2 then fullname = "C:\Temp\temp_pic.jpg"
set oyoy = ppt.ActiveWindow.Selection.SlideRange.item(1).Master
ppt.ActiveWindow.Selection.SlideRange.Shapes.AddPicture(fullname, 0,1,65,68,1024,576).select
Set yoyo = ppt.ActiveWindow.Selection.ShapeRange.item(1)
yoyo.PictureFormat.Contrast = 0.5
yoyo.PictureFormat.Brightness = 0.5
yoyo.PictureFormat.ColorType = 1
yoyo.PictureFormat.TransparentBackground = 0
yoyo.Fill.Visible = 0
yoyo.Line.Visible = 0
yoyo.Rotation = 0
yoyo.PictureFormat.CropLeft = 0
yoyo.PictureFormat.CropRight = 0
yoyo.PictureFormat.CropTop = 0
yoyo.PictureFormat.CropBottom = 0
yoyo.LockAspectRatio = -1
yoyo.ScaleHeight 1, 1, 0
yoyo.ScaleWidth 1, 1, 0
yoyo.Width = oyoy.Width/3*2
'''''set distance from top and left side
yoyo.top = 150
yoyo.Left = 290
ppt.ActiveWindow.Selection.Unselect
'Back Spec and Compass
Dim Window1
Dim WindowLayout1
On Error GoTo 0
Set PptObject = Nothing
Set Viewer1 = Nothing
''''''''''''''delete captured picture
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
fso.DeleteFile"C:\Temp\temp_pic.jpg"
Set fso = nothing
End Function
