zur Info wie es weiterging:
Durch einen DS Kontakt bekam ich folgende Info (siehe unten)
Der Hotfix kann nicht heruntergeladen werden sondern muss über ein Dassaultticket mit hoher Prio angefordert werden ! Allerdings kann man keine Smarteam R20 Tickets eröffnen da R20 ja "Out of maintenance ..." Also ein Ticket für eine aktuelle Version eröffnen und im Betreff um R20 Lösungen betteln - also die ganz normale höhere - nicht ganz begreifbare - Logik von Konzern - Supportseiten
QA00000026339
Question How does a customer request the DSLS enablement HotFixes for V5R20 SmarTeam products?
Answer DSLS is supported by SmarTeam V5R20 SP4 / SP5 / SP6 / SP7 and V5R19SP9 via HotFixes.
Minimum DSLS version able to serve V5R19/V5R20 products is DSLS V6R2013x (6.214.0 - August 8, 2012).Recommended version is DSLS V6R2013x FP1302 (6.214.2 - Dec 7, 2012) or higher.
SmarTeam HotFix availability is different, from other V4 and V5 products enabled to use DSLS, in that the development is managed by a 3rd Party and they cannot provide a generalized HotFix for this enablement.
Customers have to open a Service Request and CritSit, requesting dedicated SmarTeam HotFixes for their software level. Without a CritSit the HotFix will not be made available.
Levels supported by DSLS
2013-02-18 • Last update: 2013-07-12
[last updated on 2013 July 12]
DSLS is supported on the following release levels:
• V6R2010x and higher
• V5R21 and higher [CATIA V5, DELMIA V5, ENOVIA V5, RADE V5, SmarTeam V5, CCD V5]
• V5R20 SP7 from HF26 onwards (*)
• V5R20 SP6 from HF69 onwards (*)
• V5R20 SP5 from HF84 onwards (*)
• V5R20 SP4 from HF89 onwards (*)
• V5R20 SP3 from HF76 onwards
• V5R19 SP9 from HF96 onwards (HP-UX not supported) (*)
• V4R2.5 SP29 (HP-UX not supported)
• VPM1.7
• VPM1.6 PTF30 from HF3 onwards (HP-UX not supported)
• HFs are also available for other VPM1.6 PTFs, such as PTF28HF6, PTF26HF9, PTF22HF59
(*) SmarTeam: DSLS is supported by SmarTeam V5R20 SP4/SP5/SP6/SP7 and V5R19SP9. Customer has to request a dedicated SmarTeam HotFix
sw63
