Hi to all and sorry for my bad english.
I prepared a Project with Sub-Projects and give authorization to each of the Main Project and Sub-Projects in Smarteam. What i'am trying to do is to link CATIA product Sub-Assemblies to the Sub-Projects so that each user defined as Engineer Role can perform open the main assembly as Read Only and perform open, save, check out, check in, replace, delete etc. to theyre working assemblies (related Sub Assemblies of the Top Main Assembly). But i always get an error when the user assigned as Engineer Role try to save parts (on theyre own Sub Assemblies) when the option Secured By is enabled. If the Secured By option is not enabled everyone can perform open, save, check out, check in, replace, delete etc. operations wich normally shouldnt be. What type of authorization options must i give to the Engineer Role.
I tried to summarize the issue with some screenshoots wich can be found in the attachment.
Thanks for everyones help.
