  Vererbungs /Inheritance KE's
Autor Thema:  Vererbungs /Inheritance KE's (1484 mal gelesen)
Beere
Dipl.-Ing. Maschinenbau
erstellt am: 11. Nov. 2002 20:54    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
...zu diesem recht mächtigen KE ist mir die folgende Laus über die Leber gelaufen:
Description
A part has been opened in a linked Pro/ENGINEER session. It has got an #Inheritance and a #Cut id <number> in the model tree. Highlight the #Cut id <number> and press the right mouse button. Click #Pattern. In the Menu Manager select #Ref Pattern, #General and #Done. Save the part in the linked Pro/ENGINEER session.
In the Pro/WORKSPACE the ghost object appears with the name '<part_name>##dr0.prt' .
Alternate Technique
In Pro/INTRALINK 3.0 2001021 the modified parts can not be checked in because of the ghost object.
The relationship between ghost object and part can not be removed so that the part can not be checked in
without the ghost object.
In Pro/INTRALINK 3.0 2001200 the ghost object can be deleted if the modified part is highlighted in the Pro/WORKSPACE. Select #Object, #Modify Relationships. Highlight the ghost object part '<part_name>#dr0.prt'.
Press the button '<<' so that the ghost object disappears in the structure. Press #Ok. Erase the ghost object in the Pro/WORKSPACE and check in the modifed part.
OR
Another workaround would consist on redefining the inheritance to #independent.
Save to WS once done.Ghosts objects have disappear.
To test the issue make a modification.
Redefine dependency inheritance to dependent.
Regenerate objects to reflects changes on .drw
When saving, ghosts objects will not reappear.
Objects can be checked in without problem, being dependent again.
Resolution
This issue will be fixed in a future release of Pro/ENGINEER.
Andreas
ehlers
Pro/E 14-2001 WF1-5
erstellt am: 12. Nov. 2002 09:05    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Beere 10 Unities + Antwort hilfreich
Ich Antworte mal mit einer Frage.
Kann ich das Ursprungsteil nicht auch mit auschecken um den ganzen Schlamassel zu vermeiden.
Oder aktualisiere ich die Ghost-Datei besser einfach mit der aus der Datenbank und fertig?
Dennoch, sollte sich die Referenz des Inheritance-Features nicht eigentlich unbeeindruckt lassen!
Beere
erstellt am: 12. Nov. 2002 11:08    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi ehlers.
...das passiert auch, wenn die Dateien NEU sind, also nicht im Commonspace vorhanden sind.
...glaub es einfach... Ich dacht mich streift nen Bus als ich GhostObjekte in einem Workspace hatte, in dem nur Parts und Baugruppen ware, die neu von mir anglegt wurden.
Andreas
anagl
CREO2 M140
PDMLink 10.2 M020
HW diverse
erstellt am: 12. Nov. 2002 11:13    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für Beere 10 Unities + Antwort hilfreich
Ich glaube und hoffe,dass die Problem eigentlich bis zur Pro/E WV 2002180 entstanden sind. Nachher müsste das Problem eigentlich kleiner sein; ob das Problem nur beim IMPORT in Intralink auftritt.  Inwieweit das http://www.cad.de/foren/ubb/Forum69/HTML/000101.shtml bei INHERITANCE greift weiß ich nicht.
Weiterhin Viel Erfolg
Alois
