 | PyAnsys: Der Schlüssel zur Automatisierung von Workflows, ein Fachartikel
Thema: How to create Rigid links using Center of gravity and Moments of Interia in Ansys WB? (1134 mal gelesen)
Bruce321 Mitglied -
 Beiträge: 17 Registriert: 01.01.2015
erstellt am: 01. Jan. 2015 13:25 <-- editieren / zitieren --> Unities abgeben:
Hello, I am new to Ansys workbench. I need to analyse Rigid Body dynamics using a cross of two Rigid links attached to flexible D shaped 2d sketch. The dimensions which I have are just centre of gravity of these two rigid links and Principal moment of Inertia. Can you guys please help me on how to proceed with it? Regards, Bruce Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
N.Lesch Ehrenmitglied V.I.P. h.c. Dipl. Ing.
 Beiträge: 5296 Registriert: 05.12.2005 WF 4
erstellt am: 02. Jan. 2015 06:53 <-- editieren / zitieren --> Unities abgeben:          Nur für Bruce321
Hello Bruce, wellcomme at CAD.de. For Ansys we have also a special board, were your question would be better placed. Do you mean how to connect the 2 rigid bodies to the D-frame ? There is in Ansys a gap element for such cases. If the connetion ist flexible too, you may use a spring element. ------------------ Klaus Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
Bruce321 Mitglied -
erstellt am: 02. Jan. 2015 11:28 <-- editieren / zitieren --> Unities abgeben:
Hello Klaus, Thank you for your welcome. My problem is as stated below. A two-dimensional problem with a D-profile fender (bounding box 0.1 x 0.1 m, "circle" of the D has a diameter of 0.1 m, wall thickness 25e-3 m, m = 8 kg/m). Use the Neo-Hooke material model (C10 = 1.4040e6). Attach a cross of two rigid links with point-like masses at its ends to mock a 6 DoF model. The center of gravity is at x = -1.364601093 m, y = 0.0, z = -30.408958e-3 m, measured from the center of the flat side of the fender. The total mass is 79.2 kg, the principal moments of inertia are Ix = 8.8205288622 kgm^2, Iy = 31.4882460458 kgm^2, Iz = 36.6609663086 kgm^2. I was able to create D fender with required dimensions in ansys workbench but I don't know how to create rigid links. Can you guys please help me on how to proceed with it? Regards, Bruce [Diese Nachricht wurde von Bruce321 am 02. Jan. 2015 editiert.] Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
| | Techniker / Ingenieur (m/w/d) Entwicklung Elektrotechnik & Maschinenbau | Menschen und Technologien zu verbinden, den Perfect Match für unsere Kunden zu gestalten, immer die richtigen Expert:innen für die jeweilige Herausforderung zu finden - das ist unser Anspruch bei FERCHAU und dafür suchen wir dich: als ambitionierte:n Kolleg:in, der:die wie wir Technologien auf die nächste Stufe bringen möchte. Wir realisieren spannende Projekte für namhafte Kunden in allen Technologiebereichen ... | | Anzeige ansehen | Feste Anstellung |
Callahan Moderator Administrator PDMLink
 Beiträge: 5611 Registriert: 12.09.2002 Windchill PDMLink 11.1 M020 Creo Parametric 8.0.2.0 (produktiv) Creo Parametric 9.0.0.0 (Test) SimuFact Forming 2022
erstellt am: 03. Jan. 2015 13:49 <-- editieren / zitieren --> Unities abgeben:          Nur für Bruce321
