  Creo 3.0 Toolkit Fatal Error encountered
Autor Thema:  Creo 3.0 Toolkit Fatal Error encountered (3326 mal gelesen)
suchristian
Sehen Sie sich das Profil von suchristian an!   Senden Sie eine Private Message an suchristian  Schreiben Sie einen Gästebucheintrag für suchristian
Windows7 64bit, Visual Studio 2012 Update4, Creo3.0
erstellt am: 20. Jul. 2015 14:04    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities
Hi everyone, I've been having a big problem trying to display a model in creo with TOOLKIT on my computer.Following is my programm:
#include "stdafx.h"
#include "ProToolkit.h"
#include "ProCore.h"
#include "ProMdl.h"
#include "ProUtil.h"
#include "ProWindows.h"
#include <ProTKRunTime.h>
int main()
  char *a_char_ptr;
  a_char_ptr= "C:\\Program Files\\PTC\\Creo 3.0\\M010\\Parametric\\bin\\parametric.bat";
  ProError i= ProEngineerStart(a_char_ptr,"");
  ProError status;
  ProPath Mdlpath;
  ProType MdlType;
  ProMdl *Mdl;
  ProMdlName MdlName;
  int *w_id;
  ProStringToWstring(Mdlpath,"C:\\Users\\fsd_proe\\Documents\\bauteil1.prt");
  status =ProMdlFiletypeLoad(Mdlpath,PRO_MDLFILE_UNUSED,PRO_B_FALSE, Mdl);
  status=ProMdlTypeGet(Mdl,(ProMdlType*)&MdlType);
  status=ProMdlMdlnameGet(Mdl,MdlName);
  status= ProObjectwindowMdlnameCreate(MdlName,MdlType,w_id);
  status=ProMdlDisplay(Mdl);
  ProTKPrintf("Well done!");
  return 0;
The function "ProEngineerStart" works well, I can open creo without problem. However when I try to display a model, a window pops up that says:
Fatal error encountered. A traceback has been written to C:\Users\fsd_proe\Desktop\Toolkit\17Console1\17Console1\traceback.log. Please sent it to technical support.
According to this link Re: Creo 2.0 Parametric Fatal Error encountered, I have insert a config.pro file in the directory containing , i.e. C:\Users\fsd_proe\Desktop\Toolkit\17Console1\17Console1. But it doesn't work. In the directory C:\Users\Public\Documents, it doesn't work either.  My computer is belonging to my university and Creo is installed under username as shown above and I work also in under this username.
My OS is win7 64bit and my image card is Intel(R) G45/G43 Express Chipset.
Any help would be much appreciated! Thanks a lot!
Christian
friedhelm at work
Techniker Aluminium Profile
Sehen Sie sich das Profil von friedhelm at work an!   Senden Sie eine Private Message an friedhelm at work  Schreiben Sie einen Gästebucheintrag für friedhelm at work
erstellt am: 20. Jul. 2015 14:45    Editieren oder löschen Sie diesen Beitrag!  <-- editieren / zitieren -->   Antwort mit Zitat in Fett Antwort mit kursivem Zitat    Unities abgeben: 1 Unity (wenig hilfreich, aber dennoch)2 Unities3 Unities4 Unities5 Unities6 Unities7 Unities8 Unities9 Unities10 Unities Nur für suchristian 10 Unities + Antwort hilfreich
